Power Door Locks - Work, but not really? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Power Door Locks - Work, but not really?
New! JK/U skid plate system.We now have Uniballs!The Original 3/8" Ruffstuff Diff Cover!
Unread 10-04-2011, 11:20 AM   #1
ZickJagger
Ok, so I can hear the power door locks working on all the doors but it doesn't seem to actually lock/unlock them. Any ideas? Thanks.
ZickJagger is offline   Reply With Quote Quick reply to this message
Unread 10-04-2011, 06:50 PM   #2
ZeeJay1997
Make sure the battery voltage and grounds are good.
ZeeJay1997 is offline   Reply With Quote Quick reply to this message
Unread 10-04-2011, 08:56 PM   #3
JS97ZJ
Can they be locked from the inside (drivers module) and actually lock, and or do they lock when you hit 15 mph?
It might be a low voltage condition to the door modules, or a shorted condition tripping the circuit breaker in the junction block (passenger kick panel). The breaker (cb2) is an automatically resetting CB. If you look at the breaker while locking and unlocking, check to see if it trips and resets. If it does, disco each one individually or run it down with an ohm meter. Remember that the rear hatch is part of the system.
JS97ZJ is offline   Reply With Quote Quick reply to this message
Unread 10-04-2011, 09:17 PM   #4
JKDZ28
Does it unlock any of them? If so, you probably have some worn out door lock actuators. I have that problem on 2 of my doors.
1998 Jeep Grand Cherokee ZJ - 4.0L, NP242, IRO 2" BB
JKDZ28 is offline   Reply With Quote Quick reply to this message
Unread 10-04-2011, 09:22 PM   #5
ZickJagger
Well, I'm not running the proper battery in my car...could that be it? All of them make the unlock sound, but none of them unlock. It sounds like its not strong enough, so low voltage or the actuator could be it. All 4 work by hand.
Unread 10-04-2011, 09:32 PM   #6
moggie99
That's the problem I have - the rear doors and hatch are fine but whilst you can hear the front door actuators run, they don't actually unlock. My assumption is that the actuators are ****ed
Richard Moss
'96 ZJ 4L auto, '95 XJ 4L manual, 2003 Landrover Discovery
In the UK: 1969 MGC GT
moggie99 is offline   Reply With Quote Quick reply to this message
Unread 10-04-2011, 10:51 PM   #7
Smokey1r
Most likely the front door latch assemblies are wearing out i have an issue with them not locking randomly and not unlocking till i cycle the actuators 4 or so times then the lock and unlock cycles are perfect. Id replace them with known good ones and be done with the issue.
Smokey1r is offline   Reply With Quote Quick reply to this message
Unread 10-04-2011, 11:15 PM   #8
nwmtnbiker
Does the front passenger door unlock and lock everything?
nwmtnbiker is offline   Reply With Quote Quick reply to this message
Unread 10-05-2011, 03:26 AM   #9
moggie99
In my case it's the same from both sides - rears unlock, fronts don't. You can definitely hear the motors operate but no joy.
Richard Moss
Unread 10-05-2011, 07:53 AM   #10
Foundrydude
Take the door panels off, clean and lube all the linkages. If you hear the solenoids in the doors trying to unlock it's a mechanical issue inside the door, not an electrical/switch issue.
Generally if you hear the solenoid/popper trying to unlock then the solenoid/popper is fine.
good luck
Foundrydude is offline   Reply With Quote Quick reply to this message
Unread 10-05-2011, 08:12 AM   #11
Smokey1r
good luck
Not always the case. i uninstalled the passenger latch assembly on the jeep i drive, tore it down cleaned it and then before reassembly i tested the actuator unit with the fan gear attached to the output shaft, it will make the motor run when activated but in my case there were 2 or 3 cogs in the internal gearing that are damaged and it wont swing the gear over till it gets past the damaged part then it works once again. Unfortunately the actuator part of the door latch is a sealed unit and not easily serviceable without damaging it further.
In any event its worth a shot to disassemble the external portion of the actuator assembly test, clean, and re lube, hopefully the OP will get lucky and its just a gummed up latch as you suggest??!!
Unread 10-05-2011, 01:44 PM   #12
moggie99
Done that - the mechanical linkage moves easily enough but the electric actuator just makes noise. I'll take another look sometime soon and see if there's anything more I can do.
Thanks
Richard Moss
Unread 10-05-2011, 10:30 PM   #13
power
1994 ZJ
When I had problems with my front passenger door lock - unlock it was the electrical solenoid or motor in the door itself. I checked the two relays in the relay center first and they checked out fine. I could hear it trying to actuate but after spraying all the mechanical linkages with lubricant it still didn't work properly.
I made sure it was receiving the proper voltage at the actuator then went to the wrecker and pulled a used one and installed it in the parking lot in about 20 minutes (the door skin and plastic barrier was already off from testing). Since it was used I wired it up and tested it before installing it. There are a lot of little mechanical linkages with rods attached for the various locking systems. It helps if you have long needle nose pliers and long thin pry bar type tools. Some of the rod linkage connectors and are difficult to access inside the door if you have big hands. Remember to use adhesive to put the plastic barrier back in place as well. It was about a year ago and still works fine. I think I paid $10 for it and I had to removed it myself.
If more than one door locking mechanism went bad at the same time I would suspect the wiring or the relays. Unfortunately I cant remember the voltage the actuator was supposed to see although minimum 9Volts rings a bell. I cant remember the output from the relay.
Good luck.
94 ZJ,4.0, AX15, NP231
power is offline   Reply With Quote Quick reply to this message
Unread 10-06-2011, 08:28 AM   #14
JS97ZJ
If your able to start and operate your Jeep your problem is most likely not with the battery.
All 5 doors not operating? Very unlikely it's with one mechanical linkage.
If the problem is with one of the solenoids, the instant the locks are signaled to open, the bad one (in theory) cause a temporary short, tripping the breaker. When the signal is removed, the breaker will automatically reset.
The windows operate off off the same breaker. If you can open and close all 4 windows at the same time IMO the CB is probable fine, and a defective solenoid is causing a high current drag on the system.
Does the locks open from the inside using the drivers master switch?????
Open the panel and observe the CB, does it trip when using the key fob?
I have not looked in the manual, but is there another CB u can swap ( there are a couple in that panel)
Unread 04-28-2015, 03:55 PM   #15
jeeplady4ever
1997 FSJ Cherokee
door locks possessed
i am still waiting for my mechanic to test my PCM . i have the prblm that as soon as its wet outside my power locks engageg at 15 mph. they continuously do the safety lock non stop . once it hits that 15 mph they keep clivking. not actually unlocking. but like its repeating the safety lock . a few months ago my interior lights just stopped working. i have heard that its a pcm module. and or speed control module. or poss even transmission speed sensor. that the interior lights and power lck are controlled by these. my mechanic says the 97 loredo is controlled by the pcm . i will know tomorrow if there is a code to that or not. but my interior lights go on if i manually push them off n on. just not when i open the door, then the power locks go nuts as soon as its damp or raining out. few dry days n locks fine .
jeeplady4ever is offline   Reply With Quote Quick reply to this message
