power antenna wiring - JeepForum.com
post #1 of 1 Old 02-01-2013, 02:55 PM Thread Starter
Y0ungGunZJ
I've poked around the other threads talking about replacing this., but i don't need to replace any part of this yet.
but i'm wanting to do is (if there is one) disconnect power connectors like on all the other wiring in ZJs, if that makes sense.
or do i just need to cut a wire off the wire adapter from the stock wiring to the aftermarket radio?
i don't use the antenna, since i use usb thumb drives for all my music and i don't need my antenna to get broken if i'm not using it.
SOLVED: i did more searching and found that pulling the front left relay in the glovebox worked perfectly.
thanks,
-James
_______._____. << ----Mine------____.____.
//_|__l__,\____\,___------Dads>> /l __,[____],_
l_--\__\__l---\[]llllll[]| -----------l--|_|-L-OllllllllO-
(o) )-o---(o) )---o-) ) ---------(o) )-o-(o) )--o-) )
Y0ungGunZJ is offline
