Potential new WJ owner, what to look out for - JeepForum.com
post #1 of 5 Old 10-03-2008, 06:05 PM Thread Starter
desertdude
After having sold my 01 XJ, There is a 01 V8 WJ limited with all the bells and whistles, sunroof, leather seats etc etc on the market. Although not intially not my ideal choice, but the reasonable price, milage and all the bells and whistles ( Needs to be comfy for 2hr one way commute to and from work )caught my eye.
But I also wheel hard in the sand dunes and in very hot ambient tempratures. The XJ needed a lot of work to bring into work on the cooling system back in order and then also when pushed hard it would go upto 225. Although not overheating but driving at such high temps can't be good either for the engine or the tranny. Is the WJ the same when it comes to temp when wheeling hard ?
Also is it a reliable car to have and use as a daily driver, what are the things to look out for, I've already heard about the blend doors anything elese I should be looking out for.
Are the diffs tranny and transfercase tough mothers or can easily get screwed in the heat.
Any can anybody excatly explain what kind of 4WD system it has ( quadratech) I've heard that it has 3 auto locking diffs is this true and are they loackable on demand ???
Also need a explination of quadratech, stab-track and vari-lok
Thanks a million in advance
desertdude is offline
post #2 of 5 Old 10-03-2008, 10:19 PM
raider650
raider650 is offline
post #3 of 5 Old 10-04-2008, 07:32 AM
jwolf312
2003 WJ
Quadra-Drive came standard on Overlands and optional on Limiteds. Thats the one with Vari-lok axles front and rear. Check to see if your blend doors are shot in the climate control by holding the A/C and Recirc buttons down and turning the driver's control one click counter-clockwise. Write down the codes and check wjjeeps.com. If it says anything about blend doors it's about $1k to get it fixed right (still have dual-zone). also put the key in and cycle from On (not start) to Off (not lock) three times. The odometer will show any stored codes.
2003 Overland - Brilliant Black Pearl - 3" IRO with DT8000 shocks Energy Suspension bushings JKS BPEs - 255/75-17 BFG MT
jwolf312 is offline
post #4 of 5 Old 10-04-2008, 12:31 PM
JG_Canuck
Quadra-Drive should have a badge at the bottom of the shift bezel, and on the tailgate. Quadra-Trac will have the same 247 TC but without LSD's front and rear.
01's still had the crappy Teves calipers in front. Might want to look and see if they've been upgrade to the Akebono ones.
Once again www.wjjeeps.com is your source for all this info.
Canadian Jeep Club Member Forty-Two
JG_Canuck is offline
post #5 of 5 Old 10-10-2008, 09:21 AM
Derekne
My vehicle Wj grand cherokee uk reg T plate year 2000
engine 4.7 V8 limited petrol. 160000 miles it has done.
Heated seats they are prone to go. On some models the whole bottom part of the seat needs renewing. (mine does on both seats) the switch will work and light up but no heat. Its a costly repair. Id sooner freez my *** off than pay the 1500 dollers EACH to sort it.
Dash bord speakers crackle on after lots of usage. have a listen.
My viscous fan went in the engine bay.which was dear to fix. I have had 2 radiators replaced in 5 years. Due to constant dripping in corners underneith.
Just replace all disks and pads as they were screwed.
transmition sump was leaking fluid. As dealers had over tightened the bolts and snapped them. then never said anything and watched it drive away. The bolts go around the sump. So I replaced them had to make my own paper gasket and use black tube of gunk sealer as u cant buy the gasket?
The engine oil costs an arm and a leg for serviceing up to 60 pound in the uk. (110 dollers aprx)
I have just replaced the entire rear exhaust up to the cat as its all one part. This costed around 300 pound (600 dollers)
Wile reading through my past jeep history from prevoius owner.
The diff in the past had some problems where pinion and all bearings needed sorted. on a 3 yearly ongoing event. Due to past noises. None at present.
The air con needs a condenser as it isnt working well. The dealer diagnosed it with prev owner 5 years ago its never been repaired.
The fuel pump was replaced 4 years ago from dealer with prev owner.
Replaced cv boots.
Hope some of this helps?
"Born in lust Turn to dust, Born in sin ....come on in"
Derekne is offline
Potential Jeep Owner...again jdbell2004 ZJ Grand Cherokee Forum 18 03-01-2008 08:59 AM
Potential ZJ owner needs help uncc09meet ZJ Grand Cherokee Forum 3 07-29-2007 09:07 PM
Potential GC owner - tow pkg question KeithMW ZJ Grand Cherokee Forum 8 05-08-2007 11:30 AM
Newbie/potential WJ owner Xintaller ZJ Grand Cherokee Forum 18 07-18-2005 06:52 PM
New member and Potential 05 GC Owner Snape315 ZJ Grand Cherokee Forum 2 10-16-2004 11:58 PM
