Post pics of a ZJ with a 3.5" IRO lift with 31 or 32" tires here!! - Page 4 - JeepForum.com
post #46 of 99 Old 12-19-2008, 12:31 PM
Haleyrz
i'd want the RE for front and rear springs and the control arms. To get the IRO kit to compare to the RE kit it would cost $875 with no shocks. RE super-ride with adding their front track bar would be $895 with no shocks, plus looks like you get a little more like dissconnect adapters.
RE 3.5" Lift
RE1150 ~ SWAY BAR END LINKS, ZJ REAR
RE1172 ~ DISCONNECT ADAPTERS TJ/ZJ 96+
RE1175 ~ SWAY BAR END LINKS XJ/ZJ/TJ
RE1341 ~ COIL SPRINGS ZJ 3.5" FRONT/PA
RE1343 ~ COIL SPRINGS ZJ 3.5" REAR/PAI
RE1604 ~ TRACK BAR BRACKET, ZJ REAR
RE3705 ~ CONTROL ARM SR2 LOWER FIXED
RE3720 ~ CONTROL ARM SR2 LOWER ADJ
RE1600 ~ TRACK BAR, FRONT XJ/MJ/ZJ/TJ
= $895
IRO 3.5" Lift
3.5" Lift Front Coil Springs
Heavy Duty Double Shear Track Bar Conversion
Extended Front Sway Bar Links
Extended Rear Sway Bar Links
3.5" Lift Rear Coil Springs
B+C Custom Control Arms
Track Bar drop bracket
= $875
So...thats why
1998 ZJ Laredo, 4.0L, 2WD, it's boring
Haleyrz is offline
post #47 of 99 Old 12-19-2008, 12:41 PM
Jones
Consider the following...
Jones's Avatar
RE 3.5" Lift
= $895
IRO 3.5" Lift
3.5" Lift Rear Coil Springs+
= $875
So...thats why
Why would you need to buy rear 3.5" coil springs? It's a front to rear swap.
Jones is offline
post #48 of 99 Old 12-19-2008, 12:43 PM
Haleyrz
I know, but my front springs are sagging, and might as well replace them all and never have to worry about it
Haleyrz is offline
post #49 of 99 Old 12-19-2008, 12:47 PM
Jones
Jones's Avatar
True and IRO has a warranty for sagging springs. So as long as you have them you'll never have to worry about it.
Jones is offline
post #50 of 99 Old 12-19-2008, 01:27 PM
daufuskieraised
Well you dont technically need control arms for 3.5" so I personally would get the IRO without them and then get all adjustables when you want to go bigger. But whatever, they are both great kits and its whatever your preference is.
1996 ZJ Laredo
1.75"BB, Monroe Shocks
Cheap Radioshack CB radio
Magnet antenna
daufuskieraised is offline
post #51 of 99 Old 12-19-2008, 02:20 PM
spife7980
^ x2 save where you can cus you know you will have the urge. its inevitable.
and IRO doesnt warranty the springs. rough country does. just wanted to add that in there.
-James
Got to love an ORVIS guy...
IRO 5.5", Front LA & Double Sheer TB, Rear Adj SA and TB, JKS Quick Discos, Bilstein 5125, 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs
JCR Stage 2 Sliders, IRO Trans Skid, Carolina Drive shaft, IRO exhaust
spife7980 is offline
post #52 of 99 Old 12-19-2008, 02:44 PM
Reswob
RE 3.5" Lift
= $895
IRO 3.5" Lift
= $875
So...thats why
Try IRO 3.5", $475. All you need. Almost half the price of RE.
'11 WK2 Limited 5.7
Looking for a WK2 full size spare tire and 18" rims
Reswob is offline
post #53 of 99 Old 12-19-2008, 04:31 PM
Haleyrz
I understand the initial price difference, but I added to the IRO kit to MATCH the RE kit to prove that they aren't THAT much in a price difference, if you were going to do what I'm going to do, which is do it all at once. I know the springs are warrented, which is awesome. But my STOCK springs are the ones sagging, hence the reason why I added the rear springs in the first place. Regardless of if I go with the IRO or the RE, it will be about a year before I could EVER afford to do either after lift, wheels, tires, etc. I've got to get through college first and get a good job going, because retail doesn't pay for crap.
Haleyrz is offline
post #54 of 99 Old 12-19-2008, 04:53 PM
paddingtonbear
front to rear is useless, get new springs. Your fronts will never match up nicely, as they have much more wear on them, and are of a different quality and spring rate.
JEEP ZJ-
3.5 inch lift
(all the steering goodies/upgrades)
Crager soft 8-32x10.5x15 AT
Kevinsoffroad Radiator support/tow hooks
Kevinsoffroad Sliders
paddingtonbear is offline
post #55 of 99 Old 12-19-2008, 05:06 PM
RingRingRing
even with only 69k on your jeep?
RingRingRing is offline
post #56 of 99 Old 12-19-2008, 05:23 PM
Reswob
Yes, but you don't NEED everything that comes in the RE kit. Control arms I'm guessing is the biggest unnecessary expense. You definitely don't need them at 3.5"
'11 WK2 Limited 5.7
Reswob is offline
post #57 of 99 Old 12-19-2008, 05:35 PM
Reswob
A LOT of JF'ers have found the F>R to be extremely useful, especially on a budget. I'm planning on new rear springs at some point down the road, but a set of 3/4" spacers was a hell of a lot cheaper when I had just dropped ~$500 on a lift. I think it works just fine...
'11 WK2 Limited 5.7
Reswob is offline
post #58 of 99 Old 12-20-2008, 01:58 AM
paddingtonbear
I guess my situation was different, I am living in a situation where i dont have the space or tools to do heavy mechanics on my jeep, so i had a suspension shop do it. While im paying someone to do it i wasn't going to go half way. Even if I wasn't paying anyone, i just dont see the point in putting coils you know you'll eventually want to switch out. I got all new rear coils from IRO for 100 flat if i remember correctly, and even then they had cheaper, check out their sales/misc section they sell OEM front coils (not used) there all the time, I think for 50 bucks... might as well get it with the kit as your paying for the shipping for everything else.
Just my opinion.
JEEP ZJ-
3.5 inch lift
post #59 of 99 Old 12-20-2008, 07:53 AM
spife7980
why would you ever feel the need to switch them out? the only reason i want to is because i would eventually like to go up to 5.5" but thats a big step that will take a long time to afford.
i guess in your situation i can see why you would but if someone is trying to do it on a budget it is an excellent alternative that will save you some dough.
-James
post #60 of 99 Old 12-20-2008, 08:44 PM
Haleyrz
when lifting a vehicle you need longer control arms to position your axle correctly. Starts at 3.5" to above. So yes, technically you can get away with not needing new control arms, but your axles will be slightly out of place , positioning it back a bit and creates bump steer, and a mess of other problems. So by updating your control arms, track bar, and maybe even your tie rod will help in preventing bump steer allow you to turn better. Not to mention that changing all the springs at the same time will be more convenient and a better ride. Not to say that IRO isn't a good kit, I just think RE is better, IMO. In the end, opinions of other people dont really matter, but I thought I would throw in a little fact to justify my reasoning a little more.
Haleyrz is offline
Closed Thread
WJ: 4" and 32"s - trimming? and post pics! JCDubya ZJ Grand Cherokee Forum 10 08-26-2007 09:11 PM
Anyone running stock 16" rims and 4.5" of lift? What size tires do you run? bjl95mustang ZJ Grand Cherokee Forum 5 02-12-2007 11:23 AM
2" lift with new Tires! with Pics 2" with 265/70 R16!! Soft 8 ZJ Grand Cherokee Forum 13 11-13-2006 07:08 PM
Pics of WJ's on 15" rims 32+" size tires Clayton00grand ZJ Grand Cherokee Forum 1 02-22-2006 07:25 AM
Pics Wanted: WJ w/2" lift and stock size tires... BlaineWasHere ZJ Grand Cherokee Forum 11 03-13-2005 08:16 AM
