Possibly my first ZJ ever!! - Page 2 - JeepForum.com
post #16 of 25 Old 09-22-2013, 06:57 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
231 = part time only
242 = full time & part time selections available
Both have 2.72 ratio
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #17 of 25 Old 09-22-2013, 07:15 PM
DarkStars
And to answer your question, yes it's a direct bolt in. That jeep is a 23 spline. All 95+tcases are 23 spline. You only have to do input shaft swaps when you get older spline count cases. The 249 is an ok case.
-Josh
1997 Grand Cherokee Limited
4.5" Rubicon Express Lift W/32x11.50R15 3.75BS Wheels/Tires. :)
DarkStars is offline
post #18 of 25 Old 09-22-2013, 07:28 PM Thread Starter
evan1395
Well then i suppose when I decide to do the swap i will go with the 231. What are the usual prices for a used (newer-ish) 231?
Another question....the D44 in the rear end of the ZJ's, did they come with Trac-Loc limited slips?
J.E.E.P (Just Empty Every Pocket)
evan1395 is offline
post #19 of 25 Old 09-22-2013, 09:00 PM
xcaliber81
I lucked out mine came with a 231 but I have pondered swapping in a 242.
xcaliber81 is offline
post #20 of 25 Old 09-22-2013, 09:34 PM Thread Starter
evan1395
So when doing the swap from the 249 to the 231...the linkage bolts right up as well? No modding neccesary.
evan1395 is offline
post #21 of 25 Old 09-22-2013, 09:39 PM
xcaliber81
Originally Posted by evan1395 View Post
The 242 is full time, right?
Yea full time and part time best of both worlds. Only reason to go 231 is they are the most customizable of the 3.
post #22 of 25 Old 09-22-2013, 10:21 PM Thread Starter
evan1395
Is there a switch that selects one or the other?
Again, does the shifter linkage just bolt right upto the 231 as it does the same to the 249?
evan1395 is offline
post #23 of 25 Old 09-23-2013, 01:29 AM
98GCLimited
The shift linkage on your jeep will work as long as the little shift tab on the donor transfer case you are swapping in is on it. (You need the tab on the donor case you buy since the 249 is too long to shift the gears properly on the other cases.)
You just adjust the length of the upper shift linkage piece that connects the transfer case shifter to the torque shaft. There is a 13mm bolt you loosen and move the adjuster up or down the shaft to adjust length and re-tighten the bolt. The shaft that connects the other side of the torque shaft to the transfer case shift tab is non adjustable.
Also the 231 is a bit stronger than the 242.
98GCLimited is offline
post #24 of 25 Old 09-23-2013, 09:47 AM Thread Starter
evan1395
Thanks again for all the info guys. If im not mistaken, the 231 is also able to take the TeraLow kit, right?
Also, does the D44 come with a Trak-Loc option in the Cherokee?
evan1395 is offline
post #25 of 25 Old 09-23-2013, 12:01 PM
98GCLimited
Yes and it would be pretty sweet to have.
