possible trackbar adjustment ? - JeepForum.com
post #1 of 8 Old 07-08-2013, 03:36 AM Thread Starter
zjilla
I ordered an IRO adj rear trackbar. Stripped the threads when i installed it and the male end was seized inside the female end. After about a day of back cranking trying to get it to come loose and re thread it...i had no other option but to cut it the length i needed it and re weld it together, making a perminant solution. I was about an inch off in my measurements and didnt realize it till after it was welded and installed on the jeep. So my question is..
Since the axle still sits one inch to the right (RHD) drivers side...can i put 1inch coil spacers to get the axle almost center again? I ask bc i can get my hands on free ones.
I would do the right thing and just order another trackbar but i am in england and getting it here is a PITA.
98 ZJ RHD. And the track bar mounts opposite on the RHD. U would think it wouldnt matter in the rear which way it mounted but they decided to go backwards on that too.
Sent from my GT-N7000 using JeepForum
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
October 2013 JK of the month
My Slowly but surely JK build thread:
zjilla is offline
post #2 of 8 Old 07-08-2013, 07:17 AM
WhiteOut
WhiteOut's Avatar
You need a trackbar to center the axle, a coil spacer doesn't locate the axle under the Jeep.
WhiteOut is offline
post #3 of 8 Old 07-08-2013, 09:41 AM
PolkaPower
Lifting the ZJ up makes the front axle go off to the driver side and the rear to the passenger side because the track bars become too short for taller heights. Lifting it up more would exasperate that problem. So no.
PolkaPower is offline
post #4 of 8 Old 07-08-2013, 01:00 PM Thread Starter
zjilla
well good thing your passenger side is my drivers side. so it will work.......?
zjilla is offline
post #5 of 8 Old 07-08-2013, 01:02 PM Thread Starter
zjilla
did you even read my post?
i know what a track bar is and does.
I know when you lift or lower the jeep it moves the axle side to side.
so my question is.......
will one inch of lift hieght be atleast one inch of axle movement from side to side?
zjilla is offline
post #6 of 8 Old 07-08-2013, 01:14 PM
WhiteOut
WhiteOut's Avatar
If it is welded too long, then adding a bit more lift will move the axle closer to center. If it is welded too short, it will move it further from center. Amount of lift does not equal amount of axle deflection.
WhiteOut is offline
post #7 of 8 Old 07-08-2013, 01:26 PM Thread Starter
zjilla
im just wondering if the amount of lift equals the amount of movement- wether it moves left or right. if it is 1 for 1 then ill just need 1inch coil spacers. if it is not even close to that, i will just order another trackbar
zjilla is offline
post #8 of 8 Old 07-08-2013, 01:52 PM
PolkaPower
This is the answer. It is not equal.
