Possible oil adapter leak fixed. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Possible oil adapter leak fixed.
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! The Original 3/8" Ruffstuff Diff Cover!The Cure for your Tie Rod Roll!
Unread 12-13-2014, 02:25 PM   #1
jalexander69
Hey everyone. This is just a tip for other noobs/intermediate level wrenchers like myself. Basically I was dripping a little bit of oil constantly for the past couple weeks and after inspecting it and doing some research online I came to the conclusion it was my oil adapter o rings that were leaking. (oil dripping off the lowest point like the oil pan, only on passengers side, etc) and before I took it all off and changed the o rings, I realized about 5 of my valve cover bolts were loose enough to tighten by hand. So I tightened them up, took it for a drive and sure enough that was my problem. Probably and obvious thing to overlook for most of you, but this may help a few others so I thought Id post. Dont overlook the simple things!! Cheers
1995 4.0 Red ZJ. 180xxxKM. 31" duratracs. 2 inch RE budget boost. Just getting started!
jalexander69 is offline   Reply With Quote Quick reply to this message
Unread 12-13-2014, 02:36 PM   #2
kg6mov
Hears the voices
kg6mov's Avatar
Last time I pulled my valve covers almost all of them were barely finger tight. Good tip!
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, Backyard parts fodder
kg6mov is offline   Reply With Quote Quick reply to this message
