Possible electrical/charging system issue. - JeepForum.com
post #1 of 1 Old 11-08-2007, 02:25 PM Thread Starter
GCherokee2001
Model: 2001 GC Laredo, 4.0
Problem: Go to start up this morning, cranking very slow and sluggish then eventually just clicking. Then not really wanting to re-crank again. Tried jump starting from another car and using one of those portable 12V multistations. She'll crank over slightly better, but still fails to start.
Symptoms: About a month ago, I had UHAUL put a receiver hitch and wiring kit on it. About two weeks after that, while driving, I started to notice random times when the radio would crackle(like interference), dash lights would dim/flicker, headlights would dim/flicker, and the ABS and BRAKE dash indicators would light up and stay on for a while. Engine would stumble a bit, as if it wanted to stall, but then return to running normal when the glitch stopped. Then the glitch would go away and be fine for a couple of days/weeks again. About Monday or Tuesday, problem came back, on my way home one night. Have also noted the symptoms during the day so not just a night driving issue. Today during lunch, I did notice that almost all the battery cells were low on water which leads me to think that it could be a charging system issue.
Solutions: Battery is a DieHard Gold that is not even two years old yet. What do you guys think it could be? Could I have a short somewhere? Could it be a computer problem? Charging issue possibly with the alternator or battery? I'm trying to find the problem while it's stuck in my driveway before I have to have it towed to a shop. Taking the battery and alternator up to Autozone tonight just to make sure, but would a faulty alternator really cause it not to fire up if it's cranking over?
2001 Grand Cherokee Laredo 4x4 (His)
-Stock
1997 Grand Cherokee Laredo 4x4 (Hers)
- Rancho RS9000's
- BFG All-Terrains 235/75 R-15
- Flowmaster Exhaust
- K&N Filter
GCherokee2001 is offline
Starting/Charging ZJ Issue Eldoradoman ZJ Grand Cherokee Forum 7 07-08-2009 08:49 PM
Ghost in Charging System? StillinSaigon ZJ Grand Cherokee Forum 2 02-18-2009 07:52 AM
Electrical/charging issue sk8142 ZJ Grand Cherokee Forum 7 11-07-2007 11:34 AM
Charging System Problem Rock1127 ZJ Grand Cherokee Forum 5 12-19-2005 10:35 AM
Charging System Problems makersman ZJ Grand Cherokee Forum 5 11-18-2005 01:52 PM
