possible bad BCM? - JeepForum.com
post #1 of 13 Old 05-18-2013, 12:56 AM Thread Starter
Muzramp
possible bad BCM?
hi, today while driving, after i parked my jeep and turned it off, I noticed when I went to start the jeep, my Guages stop working, infinity amp stop working, power windows, locks, mirrors, stopped working and the dome lights dont go on when a door is opened, key fob doesn't work. I checked the fuses for everything I could find with BCM in it. all the fuses look good, I'm going to replace them anyways to see if that is the issue.
where is the BCM located so I could possibly grab one from a junk yard and replace it.
what do you guys think the issue may be?
Muzramp is offline
post #2 of 13 Old 05-18-2013, 01:10 AM
JohnCrabtree
1994 ZJ
I'm curious as to what a BCM is? I've never heard of a BCM?
JohnCrabtree is offline
post #3 of 13 Old 05-18-2013, 01:21 AM Thread Starter
Muzramp
Body Control Module. :P also forgot to mention, I did check the wiring in the boot for driver door. The wiring is completely fine.
Muzramp is offline
post #4 of 13 Old 05-18-2013, 01:26 AM
MurdaJs
Did you check your battery terminals?
MurdaJs is offline
post #5 of 13 Old 05-18-2013, 05:04 AM Thread Starter
Muzramp
yep, i even disconnected the terminals for a few minutes to reset.
Muzramp is offline
post #6 of 13 Old 05-18-2013, 05:41 AM
KoreaZJ
1994 ZJ
BCM is used in 96-98 ZJ's. Our earlier ZJ's have many more discreet wires.
BODY CONTROL MODULE
"A Body Control Module (BCM) is used on this model to control and integrate many of the vehicle’s electrical functions and features. The BCM contains a central processing unit and interfaces with other modules in the vehicle on the Chrysler Collision Detection (CCD) data bus network. The CCD data bus network allows the sharing of sensor information. This helps to reduce wiring harness complexity, reduce internal controller hardware, and reduce component sensor current loads. At the same time, this system provides increased reliability, enhanced diagnostics, and allows the addition of many new feature capabilities."
KoreaZJ is offline
post #7 of 13 Old 05-18-2013, 02:52 PM Thread Starter
Muzramp
Well, I got a BCM from the junkyard. It still didn't fix the issue, anyone have any ideas?
Muzramp is offline
post #8 of 13 Old 05-18-2013, 04:29 PM
JohnCrabtree
1994 ZJ
BODY CONTROL MODULE
Thanks for the explanation!
post #9 of 13 Old 05-18-2013, 08:54 PM Thread Starter
Muzramp
I bought new battery terminals, that didn't fix it. I'm assuming the BCM from the JY is bad itself, ordering a different from ebay. i'll let you know what happens.
Muzramp is offline
post #10 of 13 Old 05-18-2013, 10:00 PM
massarosareloud
I'm not trying to hijack your thread muzramp, but it seems uncalled for to make a whole new thread for such a simple question. Where is the BCM? I couldn't find mine for the life of me, and I think some solder joints are going bad in it and would obviously like to reflow them.
Unfortunately I don't have a diagnosis for your problem, but I would start there. Maybe open up the old BCM and take a look around and see if anything seems amiss.
1996 Jeep Grand Cherokee Limited Edition 4.0L
3.55 axles, stock pretty much everything, except for a PSC steering gear and fuel injectors
massarosareloud is offline
post #11 of 13 Old 05-18-2013, 11:48 PM
dnuccio
clean the terminals on the battery. also wouldnt be a bad idea to go to an auto parts store and ask them to test the battery. might be bad.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #12 of 13 Old 05-19-2013, 05:39 AM Thread Starter
Muzramp
It's located under the driver dash, right under the light switches. Take off the panel under the light switch, and there is a sheet of metal with 4 screws covering it, the bcm is not visible because it is behind it. Once you unscrew it disconnect the plugs going into it. Then slide it out it is a little tricky to wiggle out.
Muzramp is offline
post #13 of 13 Old 06-05-2013, 08:53 PM Thread Starter
Muzramp
Turns out it was just a bad fuse; the big maxi fuse under the hood for power windows,locks and all that jazz. I guess I skipped that one when checking fuses... The PO had a 20 in there instead of a 50..
Muzramp is offline
