Is it possible - JeepForum.com
post #1 of 7 Old 10-06-2013, 12:29 PM Thread Starter
zRoxxah
Is it possible
Is it possible to remove the front sway bar links without use of a T55 Torx bit? On a second thought, will I need the use of this T-55 again while installing a 3.5" IRO lift? If I recall correctly I remember reading a post that said there's a t-55 for the rear trackbar...haven't gotten there yet.
I seriously hate these bits...a while ago I had the same problem when replacing my driver's side fender so I ran and got a set...can you guess the biggest size bit? Correct, it's T-50!!!
Matte Black '96 ZJ 4.0
IRO 3.5" Benchmark Lift, Bilstein 5100's, 31x10.5x15 Westlake SL369 A/T's, Moog Super Trail Boss SS, KOR Rad Support, Chopped-up Front Bumper
zRoxxah is offline
post #2 of 7 Old 10-06-2013, 12:32 PM
xcaliber81
I somehow doubt you can get away with out using the t55.
xcaliber81 is offline
post #3 of 7 Old 10-06-2013, 12:52 PM
PolkaPower
I can. I just pull the pins on my JKS
PolkaPower is online now
post #4 of 7 Old 10-06-2013, 12:53 PM
Robbie98zj
U need that bit and you'll need it more than just this time go get one u can get a whole set for 20$ or individuals for just a few dollars jmo
Robbie98zj is offline
post #5 of 7 Old 10-06-2013, 01:10 PM
Josef86
I worked at a tool store when I got the jeep. But to save dough I got my torx bits from harbor freight for $10. When installing my lift I removed all old torx bolts. Took them to hardware store and got hex head replacements. Front lower control arm caster bolts can be had at rock auto for $20 with hex head.
http://www.harborfreight.com/9-piece...set-67887.html
Josef86 is offline
post #6 of 7 Old 10-06-2013, 01:10 PM
xcaliber81
Dont get a cheapo t55 spend the $$ get a snapon or something good I had to use an impact getting mine off they were VERY tight.
post #7 of 7 Old 10-06-2013, 01:17 PM Thread Starter
zRoxxah
I ended up running to O'Reilly's anyways. With my luck I figured I'd need it again. Got ahold of my sister, she let me use her 'Yota. Clutch.
zRoxxah is offline
