popping from rear - JeepForum.com
post #1 of 8 Old 09-29-2009, 09:31 AM Thread Starter
joshuatchandler
popping from rear
When I stop, then let off the brake while turning, I hear a popping noise from the rear while rolling. It will pop several times with an increase in tempo. As the pops get closer together they get quieter, until you can no longer hear it. When stopping and releasing going straight I do not hear any noises.
I have to come to a complete stop to reproduce the problem. If I'm coasting I can turn either direction and not hear the noise.
I can feel the jeep moving with the first few (louder) pops.
Tonight I plan to do the "jack it up, grab the tire at 6 and 12, and shake it like it owes you $10" test. What else can I look at?
joshuatchandler is offline
post #2 of 8 Old 09-29-2009, 11:02 AM
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
Do you have a locker installed? It sounds like you are discribing a locker. They disengage while turning at slow speeds. Alos check the u-joints.
Group W Bench
CRAWLING 98 is offline
post #3 of 8 Old 09-30-2009, 02:36 PM Thread Starter
joshuatchandler
i doubt i have lockers.. unless they come stock on a 5.9 limited. Still havent had a chance to jack it up and look.
post #4 of 8 Old 09-30-2009, 06:53 PM
CRAWLING 98
Wheeler
Well that would be my recommendation. Jack it up and look at the u-joints and pop the differential cover to look inside.
Group W Bench
post #5 of 8 Old 09-30-2009, 07:50 PM
thegrand
1983 CJ7
ya i would put my money on the dif
83 cj7 with a 79 cj5 304 v8 2.5 inch suspension 31 10.50 15 and soa coming soon
96 grand cherokee 5.2 318 stock on 33 with a custom snorkle built not bought #116
thegrand is offline
post #6 of 8 Old 10-10-2009, 07:18 PM Thread Starter
joshuatchandler
would a locker pop more after the car has been drive for a while? and under a load, like towing a trailer?
post #7 of 8 Old 10-10-2009, 09:35 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Sounds like your limited slip and or ring and pinion are toasted. Pop the diff cover and see.
ratmonkey is offline
post #8 of 8 Old 10-12-2009, 06:29 AM Thread Starter
joshuatchandler
would you have this repaired or get a new diff from a junk yard?
231 TC popping in and out of 4wd bigbluezj94 ZJ Grand Cherokee Forum 8 01-27-2010 07:48 PM
rear window not popping open robbennett_4409 ZJ Grand Cherokee Forum 3 07-16-2007 10:21 AM
Popping in rear when 4WD engaged Nailz Jeeper ZJ Grand Cherokee Forum 2 12-06-2005 07:32 PM
Popping noise in left rear wheel UM John ZJ Grand Cherokee Forum 2 06-15-2004 11:13 AM
popping out of 4wd HUNTER1877 ZJ Grand Cherokee Forum 4 05-20-2004 12:17 PM
