Popping noise when turning slow - JeepForum.com
post #1 of 16 Old 01-29-2013, 10:31 PM Thread Starter
Nolvck
2010 JK Wrangler
Hey guys, I recently put a 4" rough country lift on my zj. After doing so, and putting around 200 miles on it, it started making a popping noise when turning into my driveway and parking spots. There is no play in my wheels so I don't think it's the ball joint. I also check my sway links and they seem to be fine. Any other suggestions? My cv boot on my front driveshaft looks thrashed but would that cause this popping sound only when turning? What else should I check for. Keep in mind, it did not make this noise before I lifted it.
Nolvck is offline
post #2 of 16 Old 01-29-2013, 10:36 PM
riot1987
What Tcase do you have? Bad VC?
Build thread^^
riot1987 is offline
post #3 of 16 Old 01-29-2013, 10:51 PM Thread Starter
Nolvck
2010 JK Wrangler
249 I believe. Would the vc cause noise only at low speeds?
Nolvck is offline
post #4 of 16 Old 01-29-2013, 10:55 PM Thread Starter
Nolvck
2010 JK Wrangler
Also I figured the vc would cause "hopping" to go along with the noise. Let me know if I am misinformed
Nolvck is offline
post #5 of 16 Old 01-29-2013, 10:57 PM
Ripper3494
From what I'm experiencing you are correct, but vc would make it hop some
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #6 of 16 Old 01-29-2013, 10:58 PM
riot1987
youd def be able to feel it if it was a Tcase issue. Do you have CV axles.? Maybe one of those is goin
Build thread^^
riot1987 is offline
post #7 of 16 Old 01-29-2013, 10:59 PM
riot1987
or bad ujoints
Build thread^^
riot1987 is offline
post #8 of 16 Old 01-29-2013, 11:05 PM Thread Starter
Nolvck
2010 JK Wrangler
Yeah I do have cv axels. Boots seem ok. Took it to my buddies shop for an alignment and my tie rod is seized. Started making the noise slightly after leaving his shop. He didn't seem to think that would cause the issue but I have heard of TR causing similar sounds...?
Nolvck is offline
post #9 of 16 Old 01-30-2013, 01:29 AM
Uniblurb
Uniblurb's Avatar
Probably a mute point but if you, or someone else, hasn't changed your TC out most likely it's a 242 w/o the VC. That's what my 96 4.0 came with from the factory.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is offline
post #10 of 16 Old 01-30-2013, 01:33 AM
newfieZJ
Depending on how you have the diff angle set up , it could be the steering linkage hitting the sway bar axle mount . Mine did it till I lowered the pinion a little
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #11 of 16 Old 01-30-2013, 07:22 AM
PolkaPower
If it's a limited it may have the 249. The VC is very obvious when it craps the bed. Lot of hopping and binding in tight turns. Not any popping from my experience. That is usually the track bar, CV axles(start with a clicking), Tie rod ends.
PolkaPower is online now
post #12 of 16 Old 01-30-2013, 12:12 PM
Uniblurb
Uniblurb's Avatar
Thanks for setting me straight on this Polka and wondered about that. The OP's 96 4.0 is an Orvis so he very well may have the 249 Quadra-trac AWD as opposed to my 96 4.0 Laredo 242 w/Selec-Trac 4WD. I'll try and remember that.
Uniblurb is offline
post #13 of 16 Old 01-30-2013, 02:14 PM Thread Starter
Nolvck
2010 JK Wrangler
It's definitely a 249. I'm gonna get under it tomorrow. I will let y'all know what I determine. Thanks for all the suggestions and input.
Nolvck is offline
post #14 of 16 Old 01-31-2013, 04:28 PM
Dluenz
My zj did that when the ujoints in front went bad. Only turning.
1998 ZJ Limited 5.9
Dluenz is offline
post #15 of 16 Old 02-13-2013, 02:03 AM Thread Starter
Nolvck
2010 JK Wrangler
Put in u joint driveshaft and the popping has stopped, or at least for now. I have cv axles and plan to swap then this weekend.
Nolvck is offline
cv , driveshaft , lift , popping , zj
