Popping noise front suspension - JeepForum.com
post #1 of 9 Old 08-13-2013, 04:02 PM Thread Starter
givingtheheat
1998 zj.
Just replaced the front ball joints and tie rod ends and now im getting a popping noise when turning.
Could not getting a alignment cause popping?
I greased fittings a little bit also and wd-40d the hell out of it.
givingtheheat is offline
post #2 of 9 Old 08-13-2013, 04:14 PM
PolkaPower
Originally Posted by givingtheheat View Post
1998 zj.
Re check all of the nuts and triple check the track bar. If the noise was not there before you made the repairs it's obviously something that happened during.
Also never use WD-40 as a lubricant. It's a solvent and will de grease everything.
PolkaPower is offline
post #3 of 9 Old 08-13-2013, 05:04 PM
JasonStebbins
I learned this the hard way with my serpentine belt. WD-40 dries out rubber.
Are you sure the ball joints were fully seated when you pushed them in? Sway bar link and tie rod end nuts torqued down?
My ZJ did this after I replaced all my tie rod ends. One of them wasn't tight enough and it was moving up and down against the knuckle.
Poop
JasonStebbins is offline
post #4 of 9 Old 08-13-2013, 05:11 PM
PolkaPower
Mineral spirits with some cheap oil
Formulation
WD-40's formula is a trade secret. The product is not patented to avoid completely disclosing its ingredients.[4][7] WD-40's main ingredients, according to U.S. Material Safety Data Sheet information, are:
51% Stoddard solvent
25% liquefied petroleum gas (presumably as a propellant; carbon dioxide is now used instead to reduce WD-40's considerable flammability)
15+% mineral oil (light lubricating oil)
10-% inert ingredients
The German version of the mandatory EU safety sheet lists the following safety-relevant ingredients:
6080% heavy naphtha (petroleum product), hydrogen treated
15% carbon dioxide
It further lists flammability and effects to the human skin when repeatedly exposed to WD-40 as risks when using WD-40. Nitrile rubber gloves and safety glasses should be used. Water is unsuitable for extinguishing burning WD-40.
post #5 of 9 Old 08-14-2013, 09:56 AM Thread Starter
givingtheheat
Ball joints were fully seated yes, gonna recheck the bolts on the tie rod ends cause it is coming from the one that was causing problems from the front left.
post #6 of 9 Old 08-15-2013, 10:08 AM Thread Starter
givingtheheat
The noise is coming from the front driver side, could replacing everything but the track bar cause it now pop and make noises when turning.
post #7 of 9 Old 08-15-2013, 10:29 AM
PolkaPower
When my track bar was bad it would pop during turns. Just make sure it's not the CV shaft on that side too.
post #8 of 9 Old 08-15-2013, 10:46 AM
tucsonzj
jack up the tire..put your hands at 10 and 2 then 5 and 7 and shake. See if it wobbles.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #9 of 9 Old 08-15-2013, 02:10 PM Thread Starter
givingtheheat
Its the track bar, thanks guys.
