popping in frony end - JeepForum.com
post #1 of 3 Old 07-18-2016, 03:16 PM Thread Starter
fenderman48
I have a 97 Grand Cherokee 4 wheel drive and I have a popping in the front end. It only does it when you do a hard left and it don't do it every time. Sometimes it will pop once and sometimes it will pop 4 or 5 times in a row and the popping goes with the speed of the vehicle. I have replaced all four ball joints, the drivers side (short ) axle and the stabilizer bushings with no luck. Has anyone else had this problem? Please respond quickly as I need to get this issue resolved.
fenderman48 is offline
post #2 of 3 Old 07-18-2016, 05:19 PM
GOLDWING
Do you have a Quadratrack? (full time 4wd?) If so you may have a dying viscous coupler.
If you would be so kind as to fill in your Jeeps profile, (motor, transmission, transfer case, differentials) we can help you without making guesses about the problem.
GW
2 '98 4.0 ZJs
Hers is stock, mine, BB, Aussie, 2x6 sliders, 31s, etc.
GOLDWING is offline
post #3 of 3 Old 07-18-2016, 08:03 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Check the power steering bolts holding it to the frame.
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
