Popping in front when taking off, or speeding up - JeepForum.com
post #1 of 15 Old 07-28-2006, 12:58 AM Thread Starter
dbtolman
Independant of whether or not the wheels are turned, I get popping noises when I hit the gas a little harder than normal to get some extra speed. They "feel" like they're coming from the differential up front, but I've had one bad axle replaced, and had the entire third-member, and pinion bearings replaced and the noise is still there.
Before I had the diff worked on, and after the axle was replaced, it bound up and popped very loudly as I turned the wheels right and backed up. When it did this, it actually shook the front end of the jeep up and down as I pulled out and it stopped popping.
It's a 95 GC, Full-Time 4WD. Over 100,000 miles.
Idea's? Viscous Coupler???
dbtolman is offline
post #2 of 15 Old 07-28-2006, 01:04 AM
GreenDean
GreenDean's Avatar
I would say bad CV joints but I dont think they used them yet in 1995.
GreenDean is offline
post #3 of 15 Old 07-28-2006, 01:30 AM Thread Starter
dbtolman
They did, actually. I replaced the right axle, complete with new CV, since it was bad and the popping seemed to be coming from that side. After that, it felt like the popping moved towards the center... The other CV Joint and Axle are fine.
dbtolman is offline
post #4 of 15 Old 07-28-2006, 01:58 AM
zjhitman
I would check two things. Motor mounts and the ball/socket joints at the upper ends of the front sway bar. You may have to use a pry bar to check the joints if the rubber boots are still intact. What is underneath is basically just a small ball joint. They cannot be lubricated and over time they wear out and the ball chews it's way out of the socket. Mine had over .25 inch vertical play and it took me a long time before I found where the popping was coming from. The ball end of the joint is attached to a tapered stud that goes up thru the sway bar and has a nut on top. They rust up inside and can be a bear to get apart.
zjhitman
zjhitman is offline
post #5 of 15 Old 07-28-2006, 05:59 PM
fr3db3ar
fr3db3ar's Avatar
Wow..your jeep has a 3rd member up front??? I want that version oke:
98 5.9 Some stuff attached
It's true that I'm old enough to probably have been there and done that....it doesn't make me an expert....it gives me an educated opinion.
fr3db3ar is offline
post #6 of 15 Old 07-28-2006, 06:08 PM
dwills898
I have similar very loud popping when accelerating, i think mine is coming from my transfer case, it is leaking allot of fluid, i took the front driveshaft off and the popping stoppe.
dwills898 is offline
post #7 of 15 Old 07-28-2006, 09:16 PM
anticrombie
anticrombie's Avatar
Bad u joints in the drive shaft?
Charlie
(Did y'all miss me? )
Charlie
anticrombie is offline
post #8 of 15 Old 07-28-2006, 11:18 PM Thread Starter
dbtolman
Remembered that my tranny mechanic pulled the txfr case apart and inpsected it when he did my tranny, and today I called to talk to him... He said that the Viscous Coupler is good, and everything else in the txfr case is good... So, now I know the Diff and Txfr case are good... Barring suspension issues or mounts, is there anything else simple that I can look for, given that the two complex parts are OK? I'm afraid to drive it now, since I don't know what's wrong!
dbtolman is offline
post #9 of 15 Old 07-29-2006, 12:49 PM
joeyschribar
modt likely the chain in your t-case is loose and slapping around in the caseing, i had the exact same problem, and when the front driveshaft was out, the noise was gone as well,/// i hope that helps you!
joeyschribar is offline
post #10 of 15 Old 07-30-2006, 08:19 PM Thread Starter
dbtolman
Is this something that could easily be overlooked when a mechanic has the case apart? If so, perhaps I simply need to buy a good, used Txfr case... I actually use the 4WD feature, so I'd rather keep my d-shaft in place...
Thanks for the info!
dbtolman is offline
post #11 of 15 Old 08-01-2006, 08:58 PM Thread Starter
dbtolman
Well crap.
Been OK, not popping on turns for awhile... Today, I made a turn and the popping was worse than ever, and didn't "unbind" and start driving again so quickly... In fact, when it was doing this, if I let off the gas (even on a down-slope), the vehicle wouldn't go until I straightened the wheels, and gave some gas to unbind the (whatever the &%^% it was)...
Sounds like CV Axles, right? Only, of course, I've had them checked out- and one of them was bad and replaced... Plus, there's the rebuilt diff, txfr case, etc., which all check out well... So I'm VERY confused now. (
Also,
HELP!
dbtolman is offline
post #12 of 15 Old 08-02-2006, 06:14 PM
Wilder
I've had the same issue with my 94 GC.. would "pop" when changing direction, or pop when first applying the brakes or accellerating, worsened if the actions are more demanding then normal. I dug through everything on the front end. Drive shaft, axles, steering, ball joints, sticking brakes.. everything. i was about to give up, and laying under the jeep thinking happy thoughts when i noticed the transfer case crossmember was loose on the one side... Applied some blue loctite, tightened it back up, and hasn't made a noise since.
Another time on my old ford ranger, i had a popping sound from the front, and it even locked up the front end when in 4wd. Turned out that one was teeth coming off the front diff. By the time i got out of the spot we were 4x4ing, it had pretty much chewed all the teeth off the ring, and even punched a hole in the diff housing..
But in the middle of nowhere, i did all i could in 2wd to get out of that situation. besides, a jar full of metal teeth looks good on the shelf with the rest of the broken parts.
Wilder is offline
post #13 of 15 Old 08-03-2006, 01:44 PM
skier4life16
Charlie
Ya that is probably it. CV's make more of a slapping sound and its usually when your turning. My 96 GMC Jimmy made a clicking noise when I first got going, or accelerated and it was a U joint.
skier4life16 is offline
post #14 of 15 Old 08-04-2006, 05:59 PM Thread Starter
dbtolman
When in neutral, and rolling, the Drive-shaft will still turn since it's connected to the diff, RIGHT?
If that's the case, I guess the U-Joints could be going bad... When I'm turned all the way to one direction or the other does that put more stress on the U-joints in the driveshaft? Dumb question, I know, but I'm grasping here...
dbtolman is offline
post #15 of 15 Old 08-04-2006, 09:11 PM
Virmagicus
Virmagicus's Avatar
Check those U-joints, if they are ok it is the chain in your TC, it has devloped some slack.
Jeff
Virmagicus is offline
Popping up front not CV????? spanega ss ZJ Grand Cherokee Forum 3 08-17-2008 12:45 PM
Popping Noise from Front End GraKee99 ZJ Grand Cherokee Forum 18 04-10-2008 09:59 PM
popping up front fearthedeere69 ZJ Grand Cherokee Forum 1 01-15-2008 03:32 AM
Popping from front end. 1995zj ZJ Grand Cherokee Forum 8 03-12-2007 02:40 PM
popping in front end!!! 1997zj ZJ Grand Cherokee Forum 1 05-20-2005 05:48 PM
