Poor gas mileage - JeepForum.com
post #1 of 23 Old 04-13-2003, 02:09 PM Thread Starter
Rockhound79
Rockhound79's Avatar
Poor gas mileage
New owner of a 1998 Jeep Grand Cherokee Laredo TSI. Gas mileage is about 11.5 hwy at best. Sent it back to the dealership for servicing. They ran some computer diagnostics and reset the car's computers, but to no effect. I have topped off the tires and changed the air filter, also not much help. If this is a known problem or anyone can lend helpful advice, I would greatly appreciate it.
Rockhound79 is offline
post #2 of 23 Old 04-13-2003, 04:57 PM
Ryan2son
When I purchased my Jeep last November I performed as much scheduled and preventative maintenance that I could do on my own. This included:
Mobil 1 5w30 full Synthetic oil w/mobil 1 filter
air filter
BG gas treatment (the best on the market!)
Complete drivetrain fliud change
Radiator flush
Champin spark plugs (recommended by Jeep)
- note: I don't believe my pluges were EVER changed (the best one had a .65 gap!) and this could be one of your problems. Jeep told me that you need to use the prescribed plug or it could mess up the computer. Maybe!?!?
In short since you already changed your air filter I would change your plugs and run BG gas treatment. Once you do that then fill up the tank with good gasoline, drive it (no lead foot) and get back with us.
I get ~16mpg in the city and ~21mpg on the highway.
Questions: How many miles are on your ride? Other than gas mileage does it run well?
Richard
1999 Jeep Grand Cherokee Laredo
4x4, 4.7 V8, Quadratrac II, Loaded
A Hail the Mighty Philadelphia Eagles!
Ryan2son is offline
post #3 of 23 Old 04-13-2003, 04:58 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
What type are you looking for?
What are your driving habits?
When was the last time you did a combustion chamber or "carb" cleaning?
Do you have stock tires?
Do you have a high performance intake?
What gearing do you have?
I'm asking all these questions to figure out how and maybe why your mileage isn't what you want.
I get about 11 to 12 city and 17 to 18 highway.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 23 Old 04-13-2003, 05:41 PM Thread Starter
Rockhound79
Thanks for the speedy reply fellas. I'm not overly automotively inclined plus I've had this Jeep for a little over two weeks now, I just figured solve this issue now while the dealership still remembers me. I'm pretty light on the pedal. The car rides very well with about 55K mi. (on a side note, shuddered and stalled at 65 m.p.h. week ago on 95. let it sit and was alright. have since added dry gas) anyway, im not sure what my gearing is, my intake is factory. didnt look hard at the tires yet, but they're not anything close to heavy off road diggers. i have been told too that i can get the fuel system cleaned w/ pressurized air. i've been to the EPA's website and this model is supposed to be 15 city/ 21 hwy. anything within 1-2 mpg of that is acceptable, but for a grand cherokee to be getting worse mileage than an H2 is crazy. your mileage isnt that bad Texas, i could live with that. I'll get back to you guys soon after i try some new plugs and get the injectors and such cleaned. thanks again.
post #5 of 23 Old 04-14-2003, 11:41 AM
automan25
What formula are you using to determine your mileage? If you are using the computer in the Jeep, then don't...it's not accurate, at least mine isn't. You'll have to calculate it out on paper. I get about 12cty/17hwy with the 5.2 litre engine. Those figures are based on several months of driving records.
1993 ZJ Limited 5.2 - no mods - Red with Gold (what were they thinking) trim.
automan25 is offline
post #6 of 23 Old 04-14-2003, 06:18 PM
brad335
welcome to the world of driving a jeep. They dont get good gas milage. But get a K&N filter...you wont regret it
~~Brad~~
brad335 is offline
post #7 of 23 Old 04-14-2003, 11:16 PM
g0Nzo
if it shuttered and stalled there could be a timing proble im not fermiliar with the timing drive type on your model but i know that the last mopar i had was gear to gear and it would do the same thing it turned out to be the timing. You could try a new distributor, and rotor. Replace the plug wires and plugs, gaps should be like .33-.35. And for godsakes no dry gas especially not with fuel injection. Use some STP fuel treatment 1 whole bottle for a full tank of gas get those injectors cleaned out.
g0Nzo is offline
post #8 of 23 Old 04-15-2003, 01:40 PM Thread Starter
Rockhound79
I've been computing mileage on paper, i know the on board digital readout is unreliable. its been a bit better than before up a mile or two per gal, probably the new air filter and tire pressures. im going to replace the plugs too. I might give that BG a whirl too, although its been my experience that most of these fuel additives are just a waste of money. how about that K&N filter too? they're bout $60 by me, do they take much maintenance? whats they're life expectancy?
post #9 of 23 Old 04-15-2003, 04:07 PM
automan25
I have a K&N on my 69 Mustang. I only have to clean it about once a year, and it's supposed to last through 20 cleanings. 60 bucks for 20 years of service isn't a bad investment
post #10 of 23 Old 04-15-2003, 05:58 PM
kbohip
A good fuel additive like BG or even Techron is not a waste of money. I've used them before on used cars I've just bought, and the results have been great.
2003 Grand Cherokee Overland
Brilliant Black
All options
kbohip is offline
post #11 of 23 Old 04-17-2003, 01:23 PM
Intrepidjeep
Intrepidjeep's Avatar
I tend to not use the fuel system cleaners. You can't possibly know whether your fuel system needs any sort of cleaning without getting it diagnosed. And the aftermarket fuel system cleaner advertisers sure want you to use their product regularly to keep your fuel system clean.
However, a bottle of cleaner isn't a very expensive gamble if you seem to have a problem with the vehicle.
Consumer Reports has said, in their reviews of different brands of gasolines, that if you use a decent brand name of gasoline that has good detergent additives (I recall them mentioning Chevron as well as Amoco, Texaco, Shell and one or two others), then aftermarket fuel system cleaners are usually not worth the money.
-- Marcus
Cape Canaveral, Florida
2005 Jeep Grand Cherokee Laredo 4.7L
2005 Dodge Durango SLT 4.7L
Intrepidjeep is offline
post #12 of 23 Old 04-17-2003, 05:42 PM
ILoveto4x4inNC
Jeep says only use Champion plugs? I'm running Bosch Platinums in my 5.2 and haven't had any trouble with the computer. Did help my milage, however I think it's about time to do it again. 30K miles/year in stop and go traffic is hard on plugs among other things. Been noticing the milage going back down on me, still in the 15s but it can do better. My computer shows the same as when I calculate out myself.
This aint your daddy's Jeep!
'98 ZJ with 5.2L
Stock except for Optima red top
bigger tires(30x9.50 15 BFG MTs)
Rancho RS5000 shocks
swapped in NV231
and Pioneer CD deck.
White Jeep Club member #14
ILoveto4x4inNC is offline
post #13 of 23 Old 04-19-2003, 03:38 PM Thread Starter
Rockhound79
Have yet to replace plugs, plus i need that special pliers to pull the boot off. but i did get an updated mileage computation of a tiny bit over 11 mpg for last week. filled on monday morning and by friday evening had gone through 3/4 tank. that includes about 2 hours of idling also so possibly a bit better, but not much. ive got a trusted mechanic who i might ask to check it out also. someone told me about a charcoal filter canister? has anyone heard of this component and is it linked to mileage in any way. i think its something for fuel vapors but i could be wrong.
post #14 of 23 Old 04-19-2003, 03:58 PM
Intrepidjeep
Yes the canister stores vuel vapors rising out of the gas tank -- the computer theoretically does a quick purge of the canister (I think it waits until a certain engine temp is reached), sucking the vapors into the intake.
I suppose if the canister solenoid were stuck so that you were constantly drawing air all the time through it, but I don't know how that would really affect gas mileage. Seems the computer would compensate, and you'd probably get a check engine light on the dash as well. Not sure.
-- Marcus
post #15 of 23 Old 04-20-2003, 12:48 PM
Stocker
About that K&N...
Shop around, I can't remember what I paid but it was a lot less than $60... I'm thinking maybe half that. But that's the replacement panel, not the cone. Get a service kit too; it has cleaner and oil.
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
Quadra-Drive = poor gas mileage mmschwarz1213 ZJ Grand Cherokee Forum 73 03-14-2009 10:05 AM
2001 WJ Poor Mileage - Related to ATC use? colester ZJ Grand Cherokee Forum 3 12-31-2008 01:14 PM
Gas Mileage - Great one day, poor next NoOne2 ZJ Grand Cherokee Forum 7 11-24-2007 05:34 PM
Poor Gas Mileage Questions markmaine ZJ Grand Cherokee Forum 6 03-14-2005 04:54 PM
2003 GC - loud ticking & poor mileage irjman WJ Grand Cherokee Forum 16 03-07-2003 09:25 AM
