Polyurethane VS. Forged aluminum BB lift spacers? - JeepForum.com
post #1 of 12 Old 08-16-2009, 11:29 AM Thread Starter
MyZJ98
I've been pricing different budget boost kits, including ebay ones, and for the first time that I've ever seen, they have a Forged aircraft T6061 aluminum Spacers for the F&R for $100+ship. Has any one ever used these before, and what would be the advantages/disadvantages? For the price, if they're good, I'll pick up a set & shocks, but I know nothing about these... What do you guys think?
LINK: http://cgi.ebay.com/ebaymotors/Forge...ht_1238wt_1165
Derek
'99 WJ Laredo 4.0L, 174K, NP242 (Current)
MyZJ98 is offline
post #2 of 12 Old 08-16-2009, 11:46 AM
Tiggerrrrr
They should be fine if you want to pay the extra cash for aluminum. There ARE adjustable aluminum spacers out there and I've seen some homemade steel spacers used. I just went the poly spacers since they're cheap and won't be on my Jeep too long.
'95 ZJ Limited 4.0
2.25" BB , 31 10.5 15 Treadwright MTG's on Black Rock steelies
Everything "pimpin' Gold" REMOVED!
Looking for a REAR tow hook and bracket!
Tiggerrrrr is offline
post #3 of 12 Old 08-16-2009, 01:22 PM
subliminal
1997 XJ Cherokee
With poly it may cut down on vibrations a little bit.
1997 Jeep Cherokee 4.0 Automatic NP231
subliminal is offline
post #4 of 12 Old 08-16-2009, 01:25 PM
spife7980
ive heard of bad things happening with metal spacers. the general rule as far as i can tell is to stick with poly with the exception of ACOS which are the adjustable metal ones.
-James
Got to love an ORVIS guy...
IRO 5.5", Front LA & Double Sheer TB, Rear Adj SA and TB, JKS Quick Discos, Bilstein 5125, 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs
JCR Stage 2 Sliders, IRO Trans Skid, Carolina Drive shaft, IRO exhaust
spife7980 is offline
post #5 of 12 Old 08-16-2009, 03:26 PM
elmer_fud
I was thinking poly may also be quieter. If you decide to use the metal ones make sure to reuse/replace the spring isolators (rubber disks between the springs and the body)
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #6 of 12 Old 08-16-2009, 08:06 PM Thread Starter
MyZJ98
hmm...I think maybe i should just stick with the poly spacers. I also did some research and found that some people have had bad luck with the alum. spacers. Could anybody recommend me a good brand or site they've used and have had good luck with? I looked at Kevins, but for only 2.25", theyre pretty expensive. I want to get the spacers, bump stop extensions, and extended shocks, all for a reasonable price, around $250 in total or so... Thanks
Derek
MyZJ98 is offline
post #7 of 12 Old 08-16-2009, 08:08 PM
gatorayde
A poly spacer is a poly spacer. Find the cheapest one (besides the "slip in" ones that are split) and buy it. You can usually find used ones for dirt cheap too.
gatorayde is offline
post #8 of 12 Old 08-16-2009, 08:24 PM
taythegibs
fat bobs garage (to whom i have no affiliation) has the cheapest ones that i could find on ebay that seemed like they would be any good, they have a lifetime warranty, free shipping, and 100% positive feed back
http://cgi.ebay.com/ebaymotors/Jeep-...#ht_3971wt_939
taythegibs is offline
post #9 of 12 Old 08-16-2009, 08:53 PM Thread Starter
MyZJ98
I think I'm just going to go with IRO. $60 for the 2" spacers, $140 for extended-length Hydro Shocks, and $10.90 to ship it all, for a total of $210.88. I think this is my best bet, since IRO is well-known, and I'm sure many people have ran this setup. Good enough for me. Also, I was looking at the spidertrax wheel spacers IRO sells for $99, with the stock 245/15 tires, will this cause any sort of rubbing or issues, because all i want is the wider stance, not problems. Thanks
Derek
MyZJ98 is offline
post #10 of 12 Old 08-16-2009, 09:26 PM Thread Starter
MyZJ98
On second thought, that Fat Bobs Garage set-up doesn't look like a bad idea. IRO doesn't offer anything but a 30-day return option, and FBG has free shipping. Plus theres a set of rough country (i believe shocks) on there pretty cheap too, maybe I'll grab those to go with it.
Derek
MyZJ98 is offline
post #11 of 12 Old 08-16-2009, 09:40 PM
jeep0312
I got mine from fat bobs garage. I dont remember the price i paid but i do remember it was cheaper than iro. Also the kit from fat bob is 2'' exactly but the iro kit is only 1.75'' i called both companies to confirm the size first. I went with the hydro 1000's but im not to fond with the ride quality. IMO i would have went with black diamond shocks knowing what i do now.
-Travis-
2004 Chevy Malibu, red, 2.2 ecotec, shiny wheels, loud stereo
2000 Suzuki SV650N, V-twin, Yoshimura Exhaust, Custom Rashed Paint Job...
jeep0312 is offline
post #12 of 12 Old 08-17-2009, 12:35 AM
StellaTheZJ
I've been running the same aluminum spacers in 2 trucks since about 1995. No problems, and the old XJ was shut down with over 450,000kms on it. These are billet spacers, machined for a friend and then sold to me when he went to even bigger spacers.
Apparently, some poly spacers (Daystars???) are to be avoided as they have a split in them, which allows easier installation (you don't pull the spring all the way off). The split might allow them to come off under severe loan (ie jumping). Also, some have complained of poly spacers settling/squishing.
StellaTheZJ is offline
OEM vs. polyurethane control arm bushings tomk864 ZJ Grand Cherokee Forum 10 12-27-2010 12:45 PM
Polyurethane or OEM Rubber rustynail ZJ Grand Cherokee Forum 6 03-25-2009 06:31 AM
U/C aluminum spacers stageninja ZJ Grand Cherokee Forum 3 10-01-2008 05:01 PM
3" Aluminum Spacer Lift? mr_user ZJ Grand Cherokee Forum 16 03-15-2005 03:42 PM
Aluminum coil spacers jefferskn ZJ Grand Cherokee Forum 12 01-18-2005 09:32 PM
