Poly Motor Mounts? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Poly Motor Mounts?
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 04-01-2006, 11:14 AM   #1
Bloodbath
Poly Motor Mounts?
Does anyone know if they make poly motor mounts for a zj with I6 424? If so, where can I get them?
-Bill
1998 Red Grand Cherokee Laredo
6" Lift - 32 x 11.5 BFG MT's - K&N FIPK - MSD Ignition with Magnecore wires - JKS Control Arms, Trackbars and QD's - Addco Front Swaybar - Intake Swap - U-turn Steering Conversion
Bloodbath is offline   Reply With Quote
Unread 04-21-2006, 01:18 PM   #2
stinkoman20x6
http://www.autofab.com/Jeep%20Motor%20Mounts.htm
stinkoman20x6 is offline   Reply With Quote
Unread 04-21-2006, 05:36 PM   #3
Decipticon
Ive heard that if you are going to use urethane mounts on the engine, you should also use them on the trans or else the different amount of twisting can cause the trans to crack.
Jesus is coming. Look busy.
Decipticon is offline   Reply With Quote
Unread 04-21-2006, 06:51 PM   #4
Bloodbath
Thanks
Thanks for the info guys. I decided against the poly mounts because I keep hearing they transfer way too much engine noise/vibration into the cab.
-Bill
