PO141, then PO138 ... - JeepForum.com
post #1 of 15 Old 03-22-2008, 03:47 PM Thread Starter
redhatman
redhatman's Avatar
1998 ZJ Limited 4.0L
First I got the check engine light the day before our trip. I checked the codes today before work with our MasterTech reader, it said PO141 O2 sensor heater circuit malfunction (Bank 1, Sensor 2) So I cleared the code and disconnected the o2 sensor harness on the cat. Taped off the ends and went on my way. Drove probably 2 miles with a couple erands in between. All was well, then it popped on again. I quick hooked up the scan tool again, and it read:
PO138 O2 Sensor Circuit High Voltage (Bank 1, Sensor 2)
Any ideas? Isn't Bank 1 sensor 2 the o2 on the cat?
Leaving for a trip in an hour so please help asap. Anything to be concerned about? Thanks
-Pat
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
redhatman is offline
post #2 of 15 Old 03-22-2008, 04:24 PM
Jeeples
Jeeples's Avatar
Maybe I'm misunderstanding what you wrote, but it sounds like you still have the O2 sensor disconnected, right? When you start your vehicle, the O2 sensor will heat up quicker then the exhaust (this is the heater circuit) so that it can start reading the exhaust gasses sooner and adjust fuel trims to allow the engine to reach operating temperature in the correct amount of time.
If you've left this sensor unplugged after resetting the CEL, the heater circuit will stay on for longer then is allowed by the ECU, which will result in a CEL for the heater circuit on your O2 sensor. Until you replace the sensor, you will continue to have a CEL related to it.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #3 of 15 Old 03-22-2008, 04:35 PM Thread Starter
redhatman
redhatman's Avatar
Ok, so would it be better to leave it unplugged or plug back in for the trip?
-Pat
post #4 of 15 Old 03-22-2008, 05:40 PM
Windowsrookie
I would replace it. I believe on 93-95 models it's just to tell you your cat is bad, but on 96+ it does control some engine stuff.
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive
1987 Wrangler 4.2L
Windowsrookie is offline
post #5 of 15 Old 03-22-2008, 09:02 PM
zjay
sensor 2 is the sensor either in or after the cat.
The voltage high code is just from the sensor being unplugged. Without the complete circuit, the pcm does not see the voltage going out being dropped by the sensor. Hence 'voltage high'. If it were shorted to ground, it would say 'voltage low'.
But to agree, ususlly just a sensor.
zjay is offline
post #6 of 15 Old 03-23-2008, 12:40 PM Thread Starter
redhatman
redhatman's Avatar
Well I plugged it back in for the trip and it worked fine, engine light is still on but runs fine. So you are saying just replace the O2 sensor? I looked on RockAuto.com and they have one for $29.xx plus shipping.
-Pat
post #7 of 15 Old 03-23-2008, 12:50 PM
a70eliminator
I'm thinking not 93-95 o2 sensor is before the cat so it doesn't even know it's there. Good luck getting the old one out on your 96 unless it's been out before it could be a PITA, just replace both of them while your at it.
a70eliminator is offline
post #8 of 15 Old 03-26-2008, 07:13 PM Thread Starter
redhatman
redhatman's Avatar
Ordered a Bosch downstream for $52.xx and will install it tomorrow hopefully. I will update if works.
-Pat
post #9 of 15 Old 03-31-2008, 06:36 PM Thread Starter
redhatman
redhatman's Avatar
Installed the Bosch, sucks. Still did not fix it. Has anyone ever successfully used a bosch? If you went with factory o2, how much can I expect to pay? Is there any way to bypass the sensor and have my engine light just stay off?
-Pat
post #10 of 15 Old 04-01-2008, 09:26 PM Thread Starter
redhatman
redhatman's Avatar
Installed the Mopar O2 Sensor now, cleared codes and still pops up. What else could I check?
-Pat
post #11 of 15 Old 04-01-2008, 10:01 PM
WiLieR
Sounds like it is time to get a schematic of the O2 circuit and start tracing the wires and testing for shorts in the circuit.
99 WJ Laredo - Mine once again!
WiLieR is online now
post #12 of 15 Old 04-01-2008, 10:15 PM Thread Starter
redhatman
redhatman's Avatar
yeah, I am afraid so...but I have no clue how to do any of that.
-Pat
post #13 of 15 Old 06-20-2008, 07:25 PM
Carllo
Request Code
Hi all,
Can I request the codes ODB in the panel of my JGCLaredo 98/98? I try that cycles of "on/off" 3 times, 5 times, "n" times and nothing hapens . I try several times with several ways, and nothing.
It's impossible ? Only it's possible in the 1997 or below?
I know that in the XJ simple push the "zero hodometer" when "on" the panel and the selftests hapens....
Thanks......
Carllo is offline
post #14 of 15 Old 06-20-2008, 09:18 PM
rm2001wj
rm2001wj's Avatar
It's possible for 93-97 and for 99-04, but not 98. It takes a code reader for that year.
rm2001wj is offline
post #15 of 15 Old 06-21-2008, 10:13 AM
Carllo
Thanks rm2001wj
Carllo is offline
Help '98 Laredo Grand Cherokee CEL PO138 & PO463 calkip70 ZJ Grand Cherokee Forum 0 02-10-2007 04:02 PM
