Plz Help. Fast turn signal. See details. - JeepForum.com
post #1 of 7 Old 06-05-2013, 02:44 PM Thread Starter
SirLance88
1994 ZJ
Ok, so I know that the common reason for a super fast turn signal is because a bulb may be out or going out, but that is definitely not my problem.
The left turn signal only blinks fast when I have the headlights or running lights on, turn them off, it slows down and isn't obnoxious anymore. Turn the lights on and it speeds back up immediately.
I have checked all of my lights, and they're all relatively new, replaced maybe a year or two ago, and the problem still occurred when brand new lights were installed. So what could it be that I can check or fix.
Thank you for any help you provide,
Lance
SirLance88 is offline
post #2 of 7 Old 06-05-2013, 02:47 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Lance, you may just need a need relay for the turn signals. Easy to get, easy to install.
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 7 Old 06-05-2013, 06:04 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Correct bulb number I believe is 1295na. Is that what you installed?
Originally Posted by HighLonesome
coralman is offline
post #4 of 7 Old 06-05-2013, 07:34 PM
Nick05
1994 XJ Cherokee
last time i had this happen, it was a 01 s10. the ground wasn't any good on the bumper for the license plate lights
Nick05 is offline
post #5 of 7 Old 06-05-2013, 08:20 PM
yamifj1200
"Correct bulb number I believe is 1295na. "
I had the same problem. I installed the correct bulb (1295na) and it worked to fix the fast flasher issue on my 97. The 1295na bulb has a different resistance than the common 1157 bulb found at most auto parts shops.
Eric M
yamifj1200 is offline
post #6 of 7 Old 07-21-2014, 05:21 PM Thread Starter
SirLance88
1994 ZJ
I just put in the ones required by the Haynes manual, and I am pretty sure it was the 1295a you all said. I will check into the ground but it really is only the drivers side lights and the they generally only get fast with the running lights or headlights on. I will check out the grounds
Thanks,
Lance
post #7 of 7 Old 07-22-2014, 07:56 AM
Rockhound79
Rockhound79's Avatar
Relay
Rockhound79 is offline
