Plenum repair kit...gasket is bent! Dorman or Fel-Pro? - JeepForum.com
post #1 of 7 Old 05-07-2013, 07:32 PM Thread Starter
brewcity1
Hey guys...I got the Hughes kit, and the plenum gasket is bent.
Problem being I bought it off a guy that doesn't need it anymore....so I cant return it. It looks exactly like the Dorman gasket kit seen here (minus the plenum plate):
http://www.oreillyauto.com/site/c/de...anifold+gasket
Anyway...it looks a lot beefier and thicker than the Fel-Pro gasket. The Fel-Pro looks pretty flimsy...so can I just get the Dorman plenum gasket somewhere?
I searched all over, and its only sold in a kit, but I have the kit...just need the gasket.
Or...do you guys really recommend the Fel-pro plenum gasket?
Thanks a lot guys...I really appreciate the help and guidance on this.
2004 Grand Cherokee Limited 4.7L
General Grabber AT2's 255/65/17
1" Addco rear sway bar
brewcity1 is offline
post #2 of 7 Old 05-07-2013, 09:14 PM
SpenceAK
Either of those gaskets will do. The most important part is the aluminum plate. now you have a gasket in between 2 similar metals.
SpenceAK is offline
post #3 of 7 Old 05-08-2013, 07:11 AM Thread Starter
brewcity1
OK...thanks for the help. I always get a little worried about the gasket.
I certainly dont want to tear the engine apart again due to a leak.
post #4 of 7 Old 05-08-2013, 07:38 AM
dnuccio
I use felpro gaskets wherever I can and have never had a problem with them
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #5 of 7 Old 05-08-2013, 07:41 AM Thread Starter
brewcity1
Thanks...great to know!
It just seemed like the Dorman one was a lot thinker...but it bent pretty easily, and there are like 3 bends along one side...so maybe the looks are deceiving. I'll go with the Fel-Pro gasket.
Thanks again!
post #6 of 7 Old 05-08-2013, 07:56 AM
PolkaPower
It's not the gasket that causes the leak, it's the steel plate vs. the aluminum block that causes the leak. The aluminum expands and contracts at different temps and the gasket eventually gets pushed out between the two different metals. With the aluminum plate and the aluminum block it will be fine. I used the Fel Pro.
PolkaPower is offline
post #7 of 7 Old 05-08-2013, 08:26 AM Thread Starter
brewcity1
OK..I will do the same. Thanks again!
