Quantcast Plenum Gasket - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Plenum Gasket
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 07-10-2005, 06:21 PM   #1
trailboy
Plenum Gasket
Well I replaced the plenum gasket as many of you had suggested. I had previously did a tune up on my ZJ V8 5.2 plugs (gapped 5 thousands over), wire, cap, coil, rotor. While I had the intake off I cleaned it and the fuel injectors also sprayed seafoam on the back side of the valves before reinstalling the intake. But it still sounds like it has a clatter or a ping to it. I have not tried a tank of high octane yet the gas I am running has seafoam in it. I am at a loss besides rebuilding the motor. I am going to change the oil soon and run some engine cleaner through it. Then run a straight weight oil.
I am frustrated with it. Anyone got any more ideas? the link below is to my original post.
Thanks
Tim
http://www.jeepforum.com/forum/f13/detonation-valvle-knock-164640/?highlight=ping
To conquer one trail at a time!
93 Grand 5.2L
3" Lift on 31's
Front and Rear bumpers and Trail Rails, JKS Disco's, Rustys Adjustable LCA's, Tinted windows, cold air intake, roof rack, home made storage box, alarm syst, Have Mopar performance computer havent put in yet or the 3" high flow exhaust, and future mods on the wish list.
trailboy is offline   Reply With Quote
Old 07-10-2005, 07:32 PM   #2
TheUser
sounds about like mine; not sure what the noise is and I did the exact same thing you did w/ no solution. I plan to drive mine until it dies on me.
Sorry, no ideas.
Red 1994 Jeep Grand Cherokee
5.2L, Auto, All-Time 4wd, 235/70R15 Bridgestone Revo's
TheUser is offline   Reply With Quote
Old 07-14-2005, 07:50 PM   #3
trailboy
I like your theroy, drive it till it drops. I have been debating on what to do. I was thinking of rebuilding the engine, but I was wondering about building a hopped up I6 or to just rebuild the V8 and maybe add a bigger cam. The only real problem I see in switching to the I6 is the tranny, whether or not it is the same. Just kinda dreamin about what to do. If anyone has an idea! Also I can get a core motor from the junk yard for 300 including the heads and they may through in oil pan too, this way I can rebuild at my lesuire.
Thanks
Tim
93 Grand 5.2L
3" Lift on 31's
Old 07-14-2005, 09:23 PM   #4
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I don't know if there is a way to check the PCM to see if it is not giving you the best air to fuel ratio causing the pinging. That could be a place to start....
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Glock Forum
