Please help. Strange problem! - JeepForum.com
post #1 of 10 Old 09-13-2009, 09:05 AM Thread Starter
nitrox28
Ok. I have a 97 ZJ with the 5.2 and 133k on the clock. It usually runs like a champ, but...
I start it at work this morning and drive 18 miles home stopping at red lights, etc. I pull into a parking lot to get some breakfast, and it just dies. I tried to start it and it cranks but it sounds like the motor isn't turning over. Now here's the strange part: I have full electric (radio, windows, horn, lights), full tank of gas, fuses were fine, BUT I have no gauges. No gas gauge, no temp, no oil, no volt, nada when I try to start it. They don't even twitch. WTF? Thoughts? Runs great, dies suddenly, won't start, no dash gauges, but I still have full power. I'm stumped! Thanks in advance.
-2002 WJ Laredo. 4..7, selec-trac, leather and loaded. Other than a Flowmaster Super 40 series muffler, it's all stock.
-1998 Green Laredo 4.0, Rusty's 2" BB, Skyjacker 3" softride w/SS, Nitro shocks, ARB Bullbar, KC's, 180 degree t-stat, Flowmaster 40 series, no cat, no rear swaybar, 31x10.50xSwamper SSR's, Eagle rims, K&N filter, Alpine system, bunch of other crap.
nitrox28 is offline
post #2 of 10 Old 09-13-2009, 11:29 AM
driabyor
driabyor's Avatar
1994 ZJ
I would start at the battery... the cables can corrode inside the jacket. check voltage at battery and power center
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #3 of 10 Old 09-13-2009, 11:51 AM
JensGCherokee
Mine did about the same thing but I didnt have any turn signals. I found it to be a Relay. Well at least my local mechanic did Easy enough to change out.
JensGCherokee is offline
post #4 of 10 Old 09-13-2009, 06:35 PM
ccmf22
i had that same exact issue and it was my battery no gauges no lights no security etc and this weird twitching sound from the fuses on the inside
ccmf22 is offline
post #5 of 10 Old 09-14-2009, 01:56 PM
GrNmOnStAh
I had this very same issue in my cavi a few years back...wouldnt start and when i finally did get it started(was a stick) i had no lights and radio but no gauges and as jen said it ended up it was just a relay under the hood that crapped out after my power wire to my amp let loose and shorted out on some metal exposed on the rear deck. bought a new relay for like 6 bux i think
GrNmOnStAh is offline
post #6 of 10 Old 09-14-2009, 03:00 PM
Darthteddy
1955 M-38
Yea id check battery, Battery Terminals, fuses, and Relays under the hood.
Edit
And The Relays under the Glove Box.
Dylan-19 and Yearning
93 Rubigrand - Sold... :'(
95 Grand Cherokee Limited - 5.2 Mall Crawler
55 Willy's M38a1 - 231v6, 33" Super Swampers, D44 Full Floater Rear, Locked Front and Rear, 5.38 Gears, Viair OBA, Bilsteen 5100 shocks, Dana 18, Turbo 350, S10 Power Steering, Tilt-wheel, Full Cage, Flat Fenders....
Darthteddy is offline
post #7 of 10 Old 09-14-2009, 03:37 PM
JensGCherokee
Their are relays under the glovebox. Thats were He had me go & change it out...
I pay my mechanics with Oreos & Gummie Bears!!
post #8 of 10 Old 09-14-2009, 04:49 PM
MurdaJs
same thing here. I even had my battery checked at autozone and kragen and it passed both their tests so i tested my alternator too. it was good too so then i replaced the clicking relay but the new one clicked too. my dad came up with the idea to hook up the battery from his boat. then my jeep fired right up. I have no idea why my battery passed the kragen and autozone tests but couldnt start in my jeep. FIX= new battery
MurdaJs is offline
post #9 of 10 Old 09-14-2009, 08:14 PM
rooster51
When my CPS died, my jeep had all of your symptoms. All electronics worked but the jeep just cranked but never started.
Obviously try the free stuff first, swapping around relays and such.
Terry
rooster51 is offline
post #10 of 10 Old 09-15-2009, 04:55 AM
311LJ
311Popo
311LJ's Avatar
also if you're checking wires, make sure to check the end that connects to the starter... i had problems with it not starting.. cleaned that connection (there was some corrosion) and the problem went away
John
04 TJ Unlimited, GenRight Armor, 37's
89 XJ Laredo, 31's
07 WK Overland, Hemi, Chrome bug deflector
[SOLD] Jimmer 01 WJ *2009 GCOTY*
I ♡ John
311LJ is offline
Strange problem SWDoodle ZJ Grand Cherokee Forum 2 09-05-2009 08:43 PM
Strange Problem silver_laredoSE ZJ Grand Cherokee Forum 1 09-27-2008 04:13 PM
Strange Problem when hot cundkeys ZJ Grand Cherokee Forum 8 03-21-2008 07:55 AM
Strange '05 Problem Mr Derp WK Grand Cherokee & XK Commander Forum 7 07-30-2007 06:55 AM
Strange problem bdhaley ZJ Grand Cherokee Forum 4 11-28-2005 08:44 AM
