Please help! mechanicaly inclined jgc problem. - JeepForum.com
post #1 of 4 Old 03-28-2013, 05:19 AM Thread Starter
Jeepsupreme
1994 ZJ
Hello all! I apreciate your help. i am mechanically inclined and have rulled out the obvious. Thank you to all who view, thank you even more if you can help. i am thinking of a possible reward to who ever finds this out because its my baby. Sorry if thats against the rules this is my first post have been reading for years annd looked into this for days but all say the sam cam sensor gone crank sensor gone ground your alarm......Ive ruled that out its not the problem.
My 94 zj with 190,XXX km cranks but will not start.
i was backing up one day and my jeep just shut off didnt sputter or anything.
i was getting all kinds of funky signs and multiple fault codes. I discontected the harness cleaned it tested battery was low due to cold temrature and old. put new battery in reconected pcm and codes are gone everything powers up right cranks will not start.
In last 6 months ive replacedcrank and cam sensor, battery, plugs wires distibutor rotor, asd relay, alarm functions properly, fuel is good.
I noticed no power to coil,
Allot of oil around my starter and on starter, due to a defective oil filter that cracked and pissed oil,
on my center display it sometimes used to say rear lamp faliure but they still works assuming caused by after market lights.
My questiion is when i put a test light on coil wiring harness before coil and turn key it lights up but it gets no spark and not quite sure how to test coil what ive tried have no results.
coil shot?
could the oil on starter affect the way it cranks so it still souns right but not start?
could it be something else other then what i have listed and have changed listed above? could i have messed up replacing something?
could my pcm be fried?
when i turn key everything lights up and goes out fuel pump primes air and stereo come on turn key third click and cranks until the battery dies and it wreaks like gas.
Jeepsupreme is offline
post #2 of 4 Old 03-28-2013, 05:23 AM Thread Starter
Jeepsupreme
1994 ZJ
Also i dont think i messed anything up. i used the manual and factory genuine parts all went smoothe.
post #3 of 4 Old 03-28-2013, 06:07 AM
Rich93ZJ
Take a look at this post. It has a lot of info from RatMonkey on how to troubleshoot this condition.
http://www.jeepforum.com/forum/f13/no-start-1479908/
Rich93ZJ is offline
post #4 of 4 Old 03-28-2013, 11:48 AM
JohnnyZJ
coil shot?
test light on the wire before the coil gets a signal, but it doesn't right after the coil? and there is no spark at the plugs?
that spells coil. also, a bad coil will not send a specific code saying its pooched. its rare for coils to go but they do.
i'd replace it, they cost what, 60$ at Autovalue? i'd start there. i've had a jeep just die randomly, that was the problem, and i too did the cranking issue till battery died and it reekd of fuel.
it was coil for me. it also blew up my muffler, which was kinda cool.
07' JKUR rollin on 35s
JohnnyZJ is offline
1994 zj , cranks and cranks , does not start
