please help me with my linkage!!!! - JeepForum.com
post #1 of 2 Old 05-12-2003, 09:35 AM Thread Starter
f14x4
i went out last nite and must of knocked somethin loose cause i wasnt shifting properly with my transfer case
just went under and found out that on the linkage there is a small rod that connects the transfer case to the frame of the car, and that is like the main pivot point of the transfer case shifting linkage. well mine popped out on the transfer case side and it seems that it has a little grommet to hold it in place, but i cant get it to lock back in
hopefully someone can help me out?
(0IIIII0)
THERES ONLY ONE
f14x4 is offline
post #2 of 2 Old 05-12-2003, 10:22 AM Thread Starter
f14x4
ok i got it...and ill tell everyone what i did just incase anyone else has this problem.
there is a plate on the side of the transfer case that is connected by 2 bolts. that plate has a hole that the rod for the linkage locks into via a groove in the rod and a plastic grommet in the plate.
i took the plate completely out and lined up the rod and the hole.
then i put the plate against the front drive axle out of the transfer case and used the see-saw theory to pop the rod back into place. once it snapped it it seemed locked so i put the plate back and bolted it back in. took it for a test ride and everything works fine now.
(0IIIII0)
THERES ONLY ONE
f14x4 is offline
Anyone using this TC linkage ... 1sportsdoc ZJ Grand Cherokee Forum 14 05-27-2009 04:20 PM
TC linkage DTrem08 ZJ Grand Cherokee Forum 3 12-12-2007 07:44 PM
zj steering linkage? sk8142 ZJ Grand Cherokee Forum 1 12-05-2007 11:47 AM
4WD Shift linkage micifus ZJ Grand Cherokee Forum 5 11-27-2007 11:52 AM
Which Linkage?? GCJeeper1993 ZJ Grand Cherokee Forum 10 09-07-2006 02:21 PM
