please help... hydro-lock?? - JeepForum.com
post #1 of 6 Old 05-02-2013, 01:14 PM Thread Starter
jasarge
I have a 98 Zj 3" lift on 31 MT.. I took it nose first into a water hole that was to deep.. 4.0 shut down instantly and will not turn over it has been drying out for 3 days not. All I get when I turn the key is a loud click from starter. Starter is new (after I got it out of the hole) when I open the throttle body flap I can see a nice puddle of water inside the intake.. can someone please help ill attack a photo of the hole.. smh
"I'd rather push my Jeep than drive your Ford"
jasarge is offline
post #2 of 6 Old 05-02-2013, 01:19 PM
a70eliminator
You'll have to pull the plugs and to get the water out of the cylinders. It happens to I/O boat engines alot when the flapper goes bad, bel;ieve me you want that water out ASAP pull the plugs crank the starter and it will expell the water, then reinstall and start the engine warm it up then change the oil.
a70eliminator is offline
post #3 of 6 Old 05-02-2013, 01:29 PM Thread Starter
jasarge
Turn motor over by hand is the only way.. when I hit the key it feels like its locked up..
jasarge is offline
post #4 of 6 Old 05-02-2013, 02:14 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
Won't turn over even with the plugs out? You should just have to pull the plugs and crank it to get the water out of the cylinders. Try to turn it over by hand with the plugs out.
Once the water is out, change the oil a couple times till it is completely water free.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #5 of 6 Old 05-02-2013, 02:22 PM Thread Starter
jasarge
In the process of pulling plugs now.. thx for all the help.. ill keep u posted guys :highfive
jasarge is offline
post #6 of 6 Old 05-02-2013, 03:18 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
sure hope you didn't bend anthything. a full hydrolock like that almost always breaks a connecting rod or valves.
IF you are lucky and it will spin free after you get the plugs out. you need to change every fluid in the vehicle. change the oil a few times, FLUSH the transmission as soon as you can. any water in there, even just sitting, will destroy it in short order, and change axle and t-case fluids.
always test the puddle before diving in.
ratmonkey is offline
