Please help: Check Engine Light -
post #1 of 1 Old 08-21-2002, 04:20 PM Thread Starter
1996 Grand Cherokee 4.0L
Check engine light is always on, but car runs great. A friend scanned the codes and found a RUNNING LEAN code. Both O2 sensors jump around somewhat but generally agree with each other. What is strange is the engine light goes off when we drove the car to low altitude (we're in Denver at about 6,000 feet). When we got back to Denver, light is always on again. Which sensor is most effected by altitude (atmospheric pressure)? This engine has no EGR system (unlike the V-8). Also, does this engine have a MAF sensor? There is no mention of one whatsoever in the Dodge Shop Manual. Is it called something else?
My research points to a clogged fuel injector, clogged fuel filter, faulty fuel pump, or faulty O2 sensor. But my instincts tell me it is something else since the problem goes away at low altitude.
Coincidentally, my '88 Chevy Silverado has almost the exact same problem. Light is on only at high altitude. I've changed the EGR solendoid (EGR valve checked out ok), changed O2 sensor, and fuel filter with no improvements. I feel like the Jeep has the same problem and I want to minimize replacing good parts. Hopefully some of you have had the same problem and know exactly what is wrong?
MadDogg is offline
In order to be able to post messages on the forums, you must first register.
Check Engine Light On: 1995 Jeep Grand Cherokee Limited 4x4 4.0 Engine Keith1975 ZJ Grand Cherokee Forum 7 11-04-2014 09:31 PM
Check engine light and ways to check codes cody11ca ZJ Grand Cherokee Forum 12 01-11-2011 08:04 PM
Power Washed Engine - Check Engine Light on Now Davis87YJ ZJ Grand Cherokee Forum 31 08-11-2008 08:17 AM
0 oil pressure and no check engine light? Also what trigers major check engine fault SPL Tech ZJ Grand Cherokee Forum 9 01-08-2007 07:28 AM
check engine light, engine losing power kemicalburns ZJ Grand Cherokee Forum 21 05-27-2005 01:49 PM
