Play in clutch fan. - JeepForum.com
post #1 of 27 Old 07-29-2013, 03:46 PM Thread Starter
xcaliber81
Play in clutch fan.
Is it bad to have play, I grab the fan and and pull and push and the fan clutch assy moves but the water pump shaft does not.
xcaliber81 is offline
post #2 of 27 Old 07-29-2013, 06:24 PM
JasonStebbins
Yes. It should have zero play. Also check the four bolts on the fan-to-clutch and clutch-to-water pump.
Poop
JasonStebbins is offline
post #3 of 27 Old 07-31-2013, 11:57 AM Thread Starter
xcaliber81
Got my new fan clutch today so how does it get replaced?
post #4 of 27 Old 07-31-2013, 01:03 PM Thread Starter
xcaliber81
I mine from napa does a72314 or 27961999 ring a bell is it correct?
post #5 of 27 Old 07-31-2013, 01:24 PM
JohnnyZJ
fans don't usually have play they are bolted down to the water pump. there is no bearing in a fan to wear out and get loose. if theres play in the fan then either A: your water pumps shot or B: that fans gonna fall off and kill someone because its not bolted down tight.
07' JKUR rollin on 35s
JohnnyZJ is offline
post #6 of 27 Old 07-31-2013, 01:30 PM Thread Starter
xcaliber81
Its not the fan or water pump its the fan clutch that has play and the fact I never hear it run is a good indication it does not work.
post #7 of 27 Old 07-31-2013, 02:58 PM
JohnnyZJ
then fix it if you know everything.
JohnnyZJ is offline
post #8 of 27 Old 07-31-2013, 03:18 PM Thread Starter
xcaliber81
I never said I knew everything and besides you havent seen the play for yourself have you? Ive seen the play and I know its coming fom the fan clutch and all I was asking was how do I go about changing the fan clutch it looks straight forward but just wanted to know if I was missing anything obvious.
post #9 of 27 Old 07-31-2013, 03:21 PM Thread Starter
xcaliber81
And my jeep has 490000 kms on it just so you know.
post #10 of 27 Old 07-31-2013, 03:22 PM Thread Starter
xcaliber81
The play isnt in the fan its the fan clutch that has play. Pretty sure the title says it that way.
post #11 of 27 Old 07-31-2013, 04:52 PM
JasonStebbins
Easy to change. There's four bolts that hold the fan to the water pump. Remove them and take out the fan assembly and the fan shroud together. Then there's four nuts that hold the clutch to the fan. Twenty minute job.
Poop
post #12 of 27 Old 07-31-2013, 04:59 PM Thread Starter
xcaliber81
Hey jason I read your post on your clutch fan what brand did you go with mine is a napa made in the usa.
post #13 of 27 Old 07-31-2013, 05:01 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
X you say push and pull play, how about up and down? Just asking.
Originally Posted by HighLonesome
coralman is offline
post #14 of 27 Old 07-31-2013, 05:16 PM Thread Starter
xcaliber81
Oh I actually never tried ill try before I take the old one off and post back
post #15 of 27 Old 07-31-2013, 05:28 PM
JasonStebbins
I got a Mopar fan clutch off eBay for around $75.00
The "severe duty" clutches from all my local parts stores are annoying. They are engaged 80% of the time opposed to the regular duty ones. My Mopar clutch only kicks on when I'm sitting in traffic on a hot day. Temperature never passes 210.
Poop
