Plastic painted vents behind rear window - JeepForum.com
post #1 of 19 Old 10-11-2010, 05:27 AM Thread Starter
purplecty
2003 WJ
how do you remove the painted pieces that are on each side behind the rear window? paint is all chipped up i would like to remove, sand a repaint. anybody ever done this before? maybe i should just use a wire brush and then just tape up and spray, it'll probably be easier.
purplecty is offline
post #2 of 19 Old 10-11-2010, 05:57 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I believe they just pop out.
coralman is online now
post #3 of 19 Old 10-11-2010, 08:31 AM
Osboy1
1. Open rear hatch
2. Gently work a flat head screwdriver or trim stick in between the rear hatch weatherseal and the painted plastic louvre.
3. Pry it up until the three connectors pop free
4. The front edge has some sort of sticky gunk that adheres to the window seal in front of the louvre. Just pull gently till it all breaks free.
I painted mine in flat black bedliner to match my body cladding, bumpers and other trim pieces.
Osboy1 is offline
post #4 of 19 Old 10-11-2010, 11:23 AM
tcar
I masked and painted mine in place. Easy.
tcar is offline
post #5 of 19 Old 10-11-2010, 12:59 PM
gothchick
I prolly should do mine soon... Starting to look a little oxidized. I'm kinda shying away from trying to pop them out cuz the connectors have a tendency to turn brittle and break.
gothchick is offline
post #6 of 19 Old 10-11-2010, 08:23 PM
HardcoreBrandyn
id just tape off and paint, my buddy broke his trying to pop it off and broke the clips on it.
HardcoreBrandyn is offline
post #7 of 19 Old 10-11-2010, 08:51 PM Thread Starter
purplecty
2003 WJ
i ended up just taping and masking, sanded a little with 120 grit because thats all i had. imperfections didnt all come out, but it looked a lot better than before. the paint was all coming off and showing the black from under. i just used some rustoleum white paint made for plastic. hope it sticks better than the old paint...
post #8 of 19 Old 10-12-2010, 01:54 AM
torchd
2003 WJ
or you guys can you use this...... Click the link to see the product and the final finish
faded black molding between windshield and hood- MIRACLE CURE - LS1TECH
1998 Jeep Grand Cherokee Laredo
2" BB Pucks | SkyJacker Hydro Shocks | Rubicon Wheels | Cooper 245/75/16 Tires
2002 Trans Am
Cam, Full Exhaust, Stock Heads, Stock LS6 Intake and Stock 10 bolt with 3.42s
420 RWHP and 382 RWHTQ
torchd is offline
post #9 of 19 Old 10-12-2010, 05:13 AM Thread Starter
purplecty
2003 WJ
the paint i used does not have the shine i was expecting. cap showed glossy but not really glossy. what can i do? clear coat it? spray some white gloss enamel over in a thin coat? what shall i do?
post #10 of 19 Old 10-13-2010, 03:56 PM Thread Starter
purplecty
2003 WJ
sprayed clear coat over it and it started to wrinkle. looks horrible. shoulda just left it flat LOL. guess im gonna havta resand and paint with and enamel gloss. hope it comes out better than the first time, will do better sanding this time...
post #11 of 19 Old 10-14-2010, 09:51 AM
LordHobbit
Just did mine. I was able to pop them out by hand. Cleaned up with a scotch-brite pad, no sanding. painted and clear coated. They look great!
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #12 of 19 Old 10-14-2010, 01:06 PM Thread Starter
purplecty
2003 WJ
Hobbit post a pic . what kind of paint did u use? what was the process? im Was thinking to redo with some white enamel
post #13 of 19 Old 10-14-2010, 03:36 PM
rdrbssr11
i would avoid removing them since they usually break. i just masked mine off.
-95' grand cherokee w/ 5.2. ARB & xd9000. IRO 4.5" w/ 33's. 8.8 & HP 30 w/ 4.10's both aussie locked and some other goodies.
-97' grand cherokee w/ 4.0. stock.
rdrbssr11 is offline
post #14 of 19 Old 10-14-2010, 06:04 PM Thread Starter
purplecty
2003 WJ
i just redid mine... came out ok. it was kinda windy and tape kept hitting 1 of the spots, but all in all i am happy look better than before..... i will try and remove a set from a zj at JY and scotch brite it and repaint but who knows when that'll be if ever LOL...
post #15 of 19 Old 10-14-2010, 08:04 PM
sskilla
ditto. cake
'95 ZJ: 5.2 v8 / 231 Tcase / 46RH
sskilla is offline
ever painted the plastic around the jeep 93zjgrand ZJ Grand Cherokee Forum 13 09-08-2010 08:30 AM
Plastic Vents Dillonzj ZJ Grand Cherokee Forum 2 02-01-2008 07:06 PM
Removing rear plastic vents? Dillonzj ZJ Grand Cherokee Forum 15 12-24-2007 10:35 PM
paintED the plastic!!! Kyle howard ZJ Grand Cherokee Forum 26 07-28-2005 01:49 PM
Rear Window Vents Lookin2lift ZJ Grand Cherokee Forum 1 08-27-2004 12:33 PM
