Piston skirt failure 97 ZJ 4.0l - JeepForum.com
post #1 of 8 Old 10-08-2013, 10:05 AM Thread Starter
stukimurray
Well I have been under my jeep today pulling the sump . My jeep started knocking badly a few days ago and I read up on here the conclision was a skirt failure on one of the pistons. After a struggle to get the sump or oil pan off as you call it. My fears were realised. In the bottom of the sump was lots of metal. #2 piston had exploded. I am not smart enough or have enough time to strip the engine and rebuild it and I am not rich enough to buy a recon one which leaves me two options. Scrap it or buy a second hand engine. My thought is If I buy an old one what's to say that piston won't explode as well leaving me worse off. What I am asking is how common is this problem and what mileage do they normally go at???
stukimurray is offline
post #2 of 8 Old 10-08-2013, 04:12 PM
Kevinyj95
not common in the I6 is in the l4. I6s can be found cheap paid 300$ for the last one i bought. bought a gasket kit for 100$. Never actually seen one on a I6. Ive blown piston rods thru the side of the block and pan always in water or in real deep nasty ****. but ive seen them at 300k and still going.
Kevinyj95 is offline
post #3 of 8 Old 10-08-2013, 04:14 PM
Kevinyj95
most of the time the piston will destroy the sidewall so rebuild most likey is not an option.
post #4 of 8 Old 10-08-2013, 05:33 PM
CatSplat
1994 ZJ
The piston skirt failure is definitely known to happen with high-mileage 4.0Ls, but it's not what I would call a common occurrence. In your situation I would probably go with a used motor - your block is probably pretty thrashed anyway.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #5 of 8 Old 10-13-2013, 10:48 AM
holliewood61
holliewood61's Avatar
1981 CJ7
Pulling the head to see what's going on isn't a terribly difficult task you may be able to get away with putting a piston in it. I recently had a skirt let go in my tj and it didn't tear up the cylinder. New piston, rings, and head gasket and she was back on the road
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline
post #6 of 8 Old 10-13-2013, 11:39 AM
xcaliber81
Anything in particular that can cause this other than a high mileage engine as I have a high mileage zj that i dont currently beat the snot out of.
xcaliber81 is offline
post #7 of 8 Old 10-13-2013, 11:49 AM
Martin600
Neglecting oil changes perhaps? lubrication failure, hot spots then BOOM!
I thought these engines were pretty much bomb proof if you look after them.
Martin600 is offline
post #8 of 8 Old 10-13-2013, 11:54 AM
holliewood61
1981 CJ7
Not real sure what causes it mine was relatively low mileage for a 14 yr old rig at 105k when it busted and I'm not hard on it.
08 WK bone stock
00 WJ daily driver
60 CJ5 tore down
