pinion bearing torque question - JeepForum.com
post #1 of 5 Old 12-02-2011, 10:23 AM Thread Starter
jeepcjdummy
I have a dana 30 diff and have replaced the front pinion bearing a while back (approx 150 miles on it) The pinion rear bearing was found to be faulty (originally replaced the cone but not the race, a mistake for sure) I have now replaced both the rear cone and race. The specs I have state that when torquing used bearings a 6-8 inch pound setting is correct and when torquing new bearing a 12-15 in. pound setting is needed. I currently have 8 inch pounds torque on the pinion shaft My question is whether I should increase for the new bearing or should I leave the torque lower considering the semi break in element of the inner (larger) bearing.
jeepcjdummy is offline
post #2 of 5 Old 12-03-2011, 05:25 AM Thread Starter
jeepcjdummy
failed to mention that I'm referring to bearing preload when torquing down the pinion nut on the shaft.
post #3 of 5 Old 12-03-2011, 07:05 AM
Nejeep
I would probably split the difference (10 in-lb), but I have never done a D30 so some other members may have better advice.
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #4 of 5 Old 12-03-2011, 10:07 AM Thread Starter
jeepcjdummy
Thanks for the input Nejeep,..sounds like good advice to me,...I plan to give that a go,... will have to take it real easy on the wrench,.as I'm working with a no back-off crush sleeve for the bearing preloads.
post #5 of 5 Old 12-03-2011, 07:30 PM
KJK
I've done my Dana 30 before and I'd probably shoot for 10 in. lbs also.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
Sign of a Bad Wheel Bearing or Ring and Pinion Bearing? torchd ZJ Grand Cherokee Forum 28 02-15-2014 08:14 AM
pinion bearing question/problem jr4x4 ZJ Grand Cherokee Forum 11 11-09-2011 02:58 PM
Pinion bearing preload- quick question proeliumfessus ZJ Grand Cherokee Forum 14 06-29-2011 09:56 PM
bad pinion bearing question EBT531 ZJ Grand Cherokee Forum 7 05-09-2010 09:06 AM
Pinion Bearing question and Rear Main neoncrazy101 ZJ Grand Cherokee Forum 2 10-22-2009 07:59 AM
