Pinion bearing replacement - JeepForum.com
post #1 of 1 Old 01-07-2006, 02:17 PM Thread Starter
jmaley
Hello groupies, I got a 99 WJ I6 4WD Laredo, for the past week I noticed a sound like brake grinding from the rear. I check the brake system and found nothing wrong or any indications of grinding. I've read through 99% of the posts on bearing replacement and was wondering, do both pinion bearings have to be replaced or is it usually the outer bearing that goes bad. I'm asking because if I have to have both replaced the I'll be without a ride for at lease a week after I find a shop to do it, if it's just the outer bearing then I'd tackel that myself.
Thanks
jmaley is offline
Sign of a Bad Wheel Bearing or Ring and Pinion Bearing? torchd ZJ Grand Cherokee Forum 28 02-15-2014 09:14 AM
Pinion bearing? sdog30 ZJ Grand Cherokee Forum 10 08-10-2011 01:38 PM
2000 WJ axle identification and pinion bearing replacement kkady ZJ Grand Cherokee Forum 6 01-24-2010 03:45 PM
Dana 30 pinion bearing replacement. ZeJokee ZJ Grand Cherokee Forum 5 04-21-2009 09:56 AM
D35 Pinion Bearing Replacement... JrMechanic ZJ Grand Cherokee Forum 3 04-06-2009 07:33 AM
