Pinion Bearing bad; upgrade axle? - JeepForum.com
post #1 of 3 Old 06-21-2010, 10:48 PM Thread Starter
NickkciN
So my pinion bearing is bad in my D30. I have been told the repair is going to be somewhere around $300-$350. I know I can get a D30 out of the jy for $54 but I really don't want to deal with inspecting the gears and shafts and cleaning rust and swapping them out. My dad has told me he will pay $350 for the repair which means I can spend my money on other things or use his money and my money and get somethin good, and I really want to lock the front. I have heard that an LSD won't really help me very much on rocks, is this true? If so, I can't put in a normal locker due to my TC being a damn 249. I don't have the money to replace my tc and buy a good locker.
What would you guys do in my situation?
short version: My pinion bearing is bad and I want to lock my front axle and I will have $350 from my dad + probably $200-$300 of my money to spend. What should I do?
-Nick
1995 ZJ Limited
IRO 5.5" Critical Path Long Arms
Armored and Aussie locked
NickkciN is offline
post #2 of 3 Old 06-21-2010, 10:55 PM
Wrangler11
Wrangler11's Avatar
If you can get a d30 for $54 get it. Get me one too while your at it. It's a really easy swap. Depending on what you want to do you can get an Aussie for $239. You'd still have money left over for other stuff. You could run the Aussie with the 249 if you don't see a lot of snow. Why not take the extra cash and buy a np231. I've seen them as cheap as $100 and it's a fairly easy swap.
2002 Grand Cherokee Limited
1994 Toyota Land Cruiser (camping offload toy)
Wrangler11 is offline
post #3 of 3 Old 06-21-2010, 11:29 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Well. You'd need a hpd30 with 3.73 gears to make it a worthwhile upgrade for "only" 54$. But since those are rare as hens teeth you'd need to regear, which is a bit more than your budget will allow and leave you with money for a selectable locker.
Take the 350$, buy a 100$ np231, swap input shafts(make sure you buy a 95 or newer case) and put the rest towards that pinion bearing repair and save up for a lock right or aussie. All other options arent gonna be less than 1k$ all told.
ratmonkey is offline
Sign of a Bad Wheel Bearing or Ring and Pinion Bearing? torchd ZJ Grand Cherokee Forum 28 02-15-2014 08:14 AM
2000 WJ axle identification and pinion bearing replacement kkady ZJ Grand Cherokee Forum 6 01-24-2010 02:45 PM
2000 WJ limited: spun a pinion bearing! Rebuild axle or replace it? kkady ZJ Grand Cherokee Forum 2 01-09-2010 10:37 PM
99 WJ pinion bearing mjs691 ZJ Grand Cherokee Forum 0 12-31-2009 04:28 PM
pinion bearing dirtdogg ZJ Grand Cherokee Forum 7 04-23-2008 06:43 AM
