pinion bearing/axle question - JeepForum.com
post #1 of 14 Old 09-03-2012, 01:42 PM Thread Starter
duhkooter
1994 ZJ
my pinion bearing just went in my 94 grand, i was wondering if it would be cheaper/smarter if i bought a new axle or paid someone to fix it.
duhkooter is offline
post #2 of 14 Old 09-03-2012, 04:14 PM
iser
three months in the forum, and i already see the same threads popping up every week. i can't imagine some of you guys dealing with this for 3-4 years, lol.
first of all, fill out your profile. which axles do you have? d30? d44/d35? did the front go or did the rear go? what is your current setup? are you planning to put bigger tires on or lift it? are you planning to re-gear at all? there are so many things that has to be answered before anyone can help you.
start by filling out your information so we know what we are dealing with.
p.s. 99% times, i recommend swapping.
- REST IN PEACE, RATMONKEY -
Specs- 97 ZJ 5.2L - 4" Zone Lift - 285/75R16 Cooper STT
Upcoming Projects- Front Axle Swap. On the look out for HP30.
_______________________________________________
"lead me, follow me or get the hell out of my way"
- gen. george patton
iser is offline
post #3 of 14 Old 09-03-2012, 07:48 PM Thread Starter
duhkooter
1994 ZJ
it went in the front.. i have a dana 30 axle, i have a completely stock setup. im currently saving to get a 4 inch short arm lift from rusty's and will most likely run 32's... but either way i should still swap?
post #4 of 14 Old 09-03-2012, 08:38 PM
Airborn
Pinion bearing litterally takes an hour to replace as well as the pinion seal + about $20 in parts
Just my .02
1998 Jeep Grand Cherokee Laredo 4.0L : 172,xxx miles, IRO 3.5" F>R lift, IRO Adjustable Control Arms, IRO Adjustable Track Bars, 31" Goodyear Wrangler Authority on Cragar V5's, Pavement Pounder until I get out of college :( ...Built Not Bought #650
Spend the Time and the Money the 1st Time, You'll End Up Doing it Anyway.
Airborn is offline
post #5 of 14 Old 09-03-2012, 09:08 PM
Jimh64
Just my .02
Don't you need special tools? I have read that it is simpler to just swap axles rather than work on the differential.
Jimh64 is offline
post #6 of 14 Old 09-03-2012, 09:19 PM
1slammed87
It is relativly easy to replace the pinion bearing and no special tools needed besides pressing the inner bearing on and off. But im sure a shop near you would press a new one on for you fairly cheap. You will need to pull the axles out a little to get the carrier out. so if you can do the work yourself its cheaper to fix it. Good luck
1slammed87 is offline
post #7 of 14 Old 09-03-2012, 09:47 PM
Jimh64
Is there an easy way to tell if my pinion bearing is out or my carrier bearings? I replaced both axle bearings and seals, and I still get the loud whining, howling noise. What is strange though is that is doesn't happen in reverse.
When I did the bearings, I rotated the shaft and the two small gears fell out when I had the pin out. I got them back in with those small flat shims, but I am wondering if they had to go back in the same place, because they got mixed up.
The gears were not chipped or did not seem worn out when I pulled the axles out.
Jimh64 is offline
post #8 of 14 Old 09-03-2012, 10:13 PM
KJK
That's the internet talking. 99% of them don't know *****.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #9 of 14 Old 09-03-2012, 11:06 PM
JohnnyZJ
x2
you won't know whats gone until you pull it apart anyways. could be bearings, could be gears. thats why people say its easier to swap diffs........
bearing rebuild kit is 100 bux easy. if you have the tools its a day to rebuild.
if you have a press.
toss up what the problem is..............
07' JKUR rollin on 35s
JohnnyZJ is offline
post #10 of 14 Old 09-03-2012, 11:24 PM
iser
i am the 99%!!! =D
edit: didn't realize, he said the bearings. i auto-assumed that the gears exploded. do what johnnyzj said. if you can diagnose the exact problem, try fixing it. if not, swap it. it took me a day to pull and swap, so i know swapping an axle is pretty easy too.
iser is offline
post #11 of 14 Old 09-04-2012, 05:11 AM
Technohead
94 ZJ (18 years old) + bad pinion bearing = time to rebuild the whole axle.
-Eric
Technohead is offline
post #12 of 14 Old 09-04-2012, 10:38 AM
Jimh64
It is a 95 with 165,000. I can get a 97 rear axle assembly for $250 that only has 90,000 on it. Since I am not familiar with gears and bearings, I think that might be my easiest option. My luck, I would tear into it and replace the pinion bearing and then later find out that my gears are just worn out.
Does anyone agree one way or the other?
Jimh64 is offline
post #13 of 14 Old 09-04-2012, 03:00 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Replace the whole thing...but 250 is step for a d30.
It doesn't take much time to do, but you need to know how to set the bearing preload..unless you're one of those know it all shade tee mechanics that never touches a torque wrench and just does it all by feel.
ratmonkey is offline
post #14 of 14 Old 09-04-2012, 08:19 PM
Airborn
I am used to having tools at the ready. I didnt even think about others that may not have them on stand by so if you want you can disregard my previous statement. But yes 250 is a little much. I paid 125 for my d35, granted it is a d35 but still. lol. Basically do what you feel comfortable with. If you woul drather spend just a bit more to do something you are more comfortbale with (axle swap) then do that rather than the pinion bearing
Airborn is offline
axle , grand cherokee zj , pinion bearing
pinion bearing torque question jeepcjdummy ZJ Grand Cherokee Forum 4 12-03-2011 07:30 PM
Pinion Bearing bad; upgrade axle? NickkciN ZJ Grand Cherokee Forum 2 06-21-2010 11:29 PM
bad pinion bearing question EBT531 ZJ Grand Cherokee Forum 7 05-09-2010 09:06 AM
2000 WJ axle identification and pinion bearing replacement kkady ZJ Grand Cherokee Forum 6 01-24-2010 02:45 PM
2000 WJ limited: spun a pinion bearing! Rebuild axle or replace it? kkady ZJ Grand Cherokee Forum 2 01-09-2010 10:37 PM
