04-04-2008, 07:16 PM
#1
pics of homemade front recovery brace
Just finished welding this up tonight, will post some pics when I get it mounted up, still undecided on adding a 2" reciever, the whole thing tucks up in with no loss of ground clearance at all, if i do the reciever it will come out the center of the bumper and I'll have to cut out 1 verticle grill piece.[IMG]  [/IMG]
[IMG]  [/IMG]
Think it will be strong enough for recovery?
04-04-2008, 08:33 PM
#2
what model?
On a ZJ i would tie it into the holes for the towhookes, and squash the frame between the bar and a plate
Brian 95 ZJ, 5.2 V8,160,000 miles Colorado Jeep Club member Pi
Originally Posted by Speedycat
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997
Or just tie a 12 lb fish to a one foot pipe.
04-04-2008, 09:25 PM
#3
It fits my 95 ZJ, the cross brace ties into to core support where the lower bracket for factory tow hooks would go (4 bolts) and the main brackets bolt up where the factory belly pan mounts (3 bolts per side). I put the monting ears to locate the tow hooks in the stock position.
04-04-2008, 10:22 PM
#4
zj tractor
your mounting brackets are in the EXACT SAME location as the brackets as on my front "hidden hitch" only difference is that the steel on yours is WAY thicker, how thick is that???
BTW, it looks great, and i think you should do a 2" reciever.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread: http://www.jeepforum.com/forum/f197/...ndard-1056365/
04-05-2008, 12:27 AM
#5
looks great, what kind of recovery are you putting on it D rings or hooks? that main brace looks like atleast 3/4 stock that thing must weigh about 40 lbs. put it on the scale before you put it on the jeep i want to know now.
Greg
98 zj (The Vixen) 5.2 V8, 4 in f>r, 31's,
Built not Bought member #247
SOLD:( new DD- 04 polaris sportsman
04-05-2008, 09:54 AM
#6
metal thick enough, lol....
1993 Jeep ZJ. 4.0
04-05-2008, 11:44 AM
#7
Well it may be a little overkill, but it's what I had laying around so i used it. The metal is 3/8 I didn't have any 1/4 but better too strong than too weak, and the cross piece is actually 1"x2" rectangle tubing 1/8" wall.
Today I welded a reciever to it and painted it up, I'll get another pic with it bolted up soon.
04-05-2008, 11:46 AM
#8
zj tractor
1/8" wall!!??!?!? thats kinda weak..... i would not fell comfortable yanking with that thing.
04-05-2008, 11:53 AM
#9
Andy, If you look at the design you'll notice the cross piece doesn't do much, the pulling force is applied to the frame brackets, the 1x2 rectangle is actually quite strong, same stuff most hitches are made from, the reciever itself is usually 1/4" wall, my mopar hitch in the rear is 1/8 wall and the tube is square.
04-05-2008, 12:11 PM
#10
sorry your 1x2 looked like it was solid to me i guess its not as bad and yes if the main pulling force is applied to the 3/8 then it will be plenty strong. looks like you did your HW congrats.
Greg
04-05-2008, 01:59 PM
#11
All finished it came out just how I planned I couldn't be happier, nothing hangs below the core support, just had to slightly notch the bumper cover. I'll be useing it soon to drag my boat out of storage.
[IMG]  [/IMG]
[IMG]  [/IMG]
[IMG]  [/IMG]
04-05-2008, 02:57 PM
#12
Looks great and you can't beat the price
2000 WJ 4.0L 42RE 242 TC
172,271 miles & counting
04-05-2008, 03:22 PM
#13
zj tractor
that looks frecking awsome!!!
04-05-2008, 10:17 PM
#14
looks good
04-05-2008, 10:29 PM
#15
Ok....I'll take one of those. Are you available this tuesday? haha nice work.
2002 Grand Cherokee Laredo, projector headlights, 6000k HIDs. Otherwise stock.
