Picked up a ZJ cheap - JeepForum.com
post #1 of 17 Old 01-27-2014, 09:35 AM Thread Starter
mnypitZJ
OK just picked this thing up. Its a 94 Grand Cherokee Laredo. Been looking for an inexpensive Jeep 4x4 automatic to teach my daughter how to drive. Prior to her getting her driver permit at 15 she didnt have any problem driving the 5 speed YJ on trails ect, but now that she has her permit she has completely forgotten how to drive a stick, so in the interest of saving whats left of our clutch and transmission I bought this one for $600.
It is in pretty good condition, the interior is like new other than a few stains, which I seem to be coming clean. The exterior was filthy from sitting for over a year in a carport, but it seems to be cleaning up nicely too. It will need a new r/f fender, but otherwise it is perfectly straight. We had to put a battery in it(damn they have gotten expensive!!). It is running a bit rough, but the more we drive it the better it gets. I suspect bad fuel from sitting. 4x4 works well too. Only weird issue is the transmission slips every once in a while coming off a stop. Not all the time, only sometimes.
So one quick question. The owner passed away over a year ago and its been sitting. The transmission has a pretty good leak from a botched pan gasket replacement, so the wife has been putting dollar store ATF in it, not ATF+4, but cheapo ATF. Could this be the reason its slipping once in a while? I assume from the FAQ that it is a 42RE.
541494_4025652654981_1455950822_n.jpg   1560595_4025652134968_1582333750_n.jpg   1003220_4025651574954_1667092965_n.jpg
mnypitZJ is offline
post #2 of 17 Old 01-27-2014, 03:52 PM
shaban
I'd say change over to ATF+4 (or ATF+3 if you're tight on money, but you'd have to change ATF+3 more frequently), and see how it goes.
Slipping is a general sign of a tranny being worn and in need of rebuild, however you can alleviate it with a good fluid. Put in a new filter and gasket as you're doing that, and keep an eye on metal shards/flakes in the pan.
Also these trannies are known for governor pressure solenoid and sensor going bad, but that causes some weird shifting rather than slips, as far as I know.
shaban is offline
post #3 of 17 Old 01-27-2014, 03:54 PM
dusterdude
Dollar store atf is fine if it was atf+4 but i would do a tranny service anyway
dusterdude is offline
post #4 of 17 Old 01-27-2014, 05:58 PM Thread Starter
mnypitZJ
Its weird what it does. At a light, it feels like its pulling as long as I have the brake on, then I let off the brake and step on the gas and it almost feels like the diff or transfer case slips for a couple seconds and then it grabs and goes fine. Shifts all the way up to top gear and once it grabs it pulls like it should. And it only does it once in a while, not every time.
Oh and apparently the header panels are different over the years. Picked one up in a salvage yard today and its completely different. UGH.
mnypitZJ is offline
post #5 of 17 Old 01-27-2014, 08:54 PM
shaban
Check your tranny fluid level first of all. Should be warm (a good 10 mile lap around the city should do it), idling in NEUTRAL (not park), on level surface.
These trannies are very sensitive to proper fluid level too.
shaban is offline
post #6 of 17 Old 01-27-2014, 09:22 PM Thread Starter
mnypitZJ
Yep, I did that. I was looking at a FAQ, or I think I was, yesterday that listed some common fixes yesterday and for some reason I cant find it now. Anybody got that link?
mnypitZJ is offline
post #7 of 17 Old 01-27-2014, 09:26 PM
shaban
shaban is offline
post #8 of 17 Old 01-27-2014, 09:32 PM
Myusername1674
Yep header panel and front grill was changed in 96, looks good for $600!
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #9 of 17 Old 01-27-2014, 09:46 PM Thread Starter
mnypitZJ
Originally Posted by shaban View Post
Yep that one. I found it pretty quickly the other day, but for the life of me I couldn't find it today. Thanks for the link.
mnypitZJ is offline
post #10 of 17 Old 01-28-2014, 09:47 AM
Purcell69
Nice find on your ZJ. Worst case, replace the transmission with one from a JY. There are quite a few people here who have done the junk yard tranny swap and had no problems.
When my daughter was learning to drive, I did something similar with an XJ. My daughter had issues with the 5 speed in our ZJ, so I got (actually was given) an '86 XJ with a bad motor. I swapped in a running 3.4L GM crate engine and the XJ became her learning vehicle and DD. After a year of suffering through getting up early to start her Jeep and let it warm up before leaving for school (carburerated engine) and no mishaps, I worked a deal on a lifted '99 XJ for her and sold the '86. She is about to graduate and will take the '99 to college with her. I tried to trade her for a WJ, but she wants her XJ.
Don't worry too much about the transmission. After sitting as long as it did, it may have an internal seal that is a bit stiff. Change the fluid and filter when you fix the leak and continue driving it unless the slip gets worse. It may end up fixing itself with some use.
-Joe
Purcell69 is offline
post #11 of 17 Old 01-28-2014, 10:12 AM Thread Starter
mnypitZJ
That was kinda my thoughts too Joe. If it goes it goes I guess. The u pull it yard in Daytona has about a dozen ZJs and I think 6 or 7 XJs, so I dont think I will have an issue finding a tranny.
mnypitZJ is offline
post #12 of 17 Old 01-28-2014, 10:24 AM
Purcell69
The XJ transmission will not swap with the ZJ. The XJ uses the AW-4 automatic. Still, there should be no shortage of donors if you need one. Just be sure to get one from an inline ZJ rather than a V-8, as the bellhousing bolt pattern is different.
The AW-4 could be made to work, since it bolts right up to the 4.0L engine, but there are computer issues that will create problems you don't need.
-Joe
post #13 of 17 Old 01-28-2014, 03:14 PM Thread Starter
mnypitZJ
The fluid is spotless on the stick, and I had some ATF+4 sitting on the shelf, so I did a classic drain and fill. Pulled the pan, made a gasket with the sheet of gasket material I had, and drove it. The filter looked to be fairly new. I think the person I bought it from said her husband had just did the service, but what she was putting in there was not ATF+4, it was just ATF. Took it for a spin and it didnt slip at all. Drove about 10 miles. Gonna take it for a longer ride later, but I think the problem is fixed. It does have a particularly long 2-3 shift. Not slipping, just if your on the gas a bit it takes a while to shift. If you let off the gas it goes right in.
Picked up some stock LJ rims with 30s on them, and a used fender and it looks and runs great now. Too bad the fender is a different color.
mnypitZJ is offline
post #14 of 17 Old 01-28-2014, 03:55 PM
Purcell69
-Joe
post #15 of 17 Old 01-28-2014, 04:50 PM
JohnCrabtree
1994 ZJ
If I may chime in, Get your daughter to do the work to it!! She may not enjoy it but it's her vehicle and knowing a thing or two about mechanics never hurts! Being able to do your own oil changes instead of paying jiffy lube $100+ to do it is a big deal for a college student!!
JohnCrabtree is offline
