Picked up my first ZJ!! - JeepForum.com
post #1 of 30 Old 06-01-2013, 06:39 PM Thread Starter
splavidal
Hello everybody! I finally got a '93 Grand Cherokee. I've been obsessive about these for a long time. Its got a supposedly fresh transmission and a 4.5L stroker motor. 3 inch skyjacker lift and the guy threw in a set of 4 15x8 wheels. (need some tires ASAP because it looks super lame on the tiny wheels/tires right now) Paid $1500 for it. Oh and a 249 transfer case.
A few problems... Aftermarket stereo doesn't make its way to the speakers. Driver door doesn't close all the way. VIC already drives me crazy. It leaks quite a bit of oil. Front driveshaft is out. Needs tires.
And yesterday morning I went to unlock the pass door and the alarm went off. All I could do was disconnect the battery because I had to go to work.. Now its stuck in security mode. I've tried locking/unlocking all doors with the key and its still in security mode. (lights flashing and no start) I'll be very open to recommendations on how to fix that!
Sorry for the long post, Ill get some pics of it up on here soon.
splavidal is offline
post #2 of 30 Old 06-01-2013, 06:46 PM Thread Starter
splavidal
Here's a picture
'93 Grand Cherokee
'02 WRX Cobb Stage 2
'90 Suburban
'65 Lotus 7
post #3 of 30 Old 06-02-2013, 12:51 AM
zRoxxah
That sounds like a pretty good deal! How many miles on the motor? I wish I could stroke mine..
Matte Black '96 ZJ 4.0
IRO 3.5" Benchmark Lift, Bilstein 5100's, 31x10.5x15 Westlake SL369 A/T's, Moog Super Trail Boss SS, KOR Rad Support, Chopped-up Front Bumper
zRoxxah is offline
post #4 of 30 Old 06-02-2013, 01:34 AM Thread Starter
splavidal
It was a sweet deal until the security system freaked out!
And the motor has 1000 miles on it. It has a lot more power than my dads 4.0 in his TJ. Only downside is that it seems to have a valve tick and lower oil pressure. Don't know where to start on that one.
'93 Grand Cherokee
'90 Suburban
'65 Lotus 7
post #5 of 30 Old 06-02-2013, 07:04 AM
tucsonzj
if your front drive shaft is out the VC in your 249 might be shot. Good luck with that when you hook it back up. stereo, usually the wiring at the speakers is an issue when theyre the stock speakers. Going to have to check all the wiring.
Find out where the oil is dripping from, could be a bad sign.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #6 of 30 Old 06-02-2013, 09:59 AM
monkeyhouse
I haven't tried this, but the PO for my ZJ said the security system was going off and he didn't have the remote to shut it off. He ended up disabling the security, but he told me that to turn it off manually, he went to the front passenger door and turned the key four times to get it to stop.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #7 of 30 Old 06-02-2013, 10:54 AM
dnuccio
no offense but i think you overpaid for it
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #8 of 30 Old 06-02-2013, 03:03 PM
um7267
could pull the alarm fuse? that might help
2004 Lexus Es330, alive; 1999 Cherokee Sport
1998 Grand Cherokee, sold
1997 Grand Cherokee; Black and Gold, Limited 4.0....RIP 2005
to the good times and the bad, the family we have and lost, little brother 1988-2011
um7267 is offline
post #9 of 30 Old 06-02-2013, 07:27 PM
TKFlight
I had the same problem in my '95 ZJ, this is what I did. If you have a spare key have someone turn the key in the passenger door as you start it up.
TKFlight is offline
post #10 of 30 Old 06-02-2013, 07:27 PM
Rich93ZJ
Looks like the hood flew up while driving . 249 is a great case but if the vc is bad, your going to pay 2-300 for the vc alone. May want to consider a t/c swap. Much cheaper in the long run. Be prepared to spend some money
Rich93ZJ is offline
post #11 of 30 Old 06-02-2013, 07:35 PM
WhiteOut
WhiteOut's Avatar
The TC is shot if the driveshaft is out. Also, you'll have to be careful since it will roll in park.
WhiteOut is offline
post #12 of 30 Old 06-02-2013, 07:41 PM
driftwood00
All I have to do when my security goes off, which is quite often, is go to the back hatch and put the key in and unlock and lock it.
1995 JGCL
4.0L
4x4
driftwood00 is offline
post #13 of 30 Old 06-02-2013, 10:10 PM
Rich93ZJ
Very good point.....Op, make sure your e-brake is in good working order
Rich93ZJ is offline
post #14 of 30 Old 06-03-2013, 12:11 AM Thread Starter
splavidal
Well that makes sense now! It doesn't seem to stay where I leave it. And the ebrake needs some tightening. Did some already but it wasn't enough.
'93 Grand Cherokee
'90 Suburban
'65 Lotus 7
post #15 of 30 Old 06-03-2013, 12:14 AM Thread Starter
splavidal
I finally got it out of security mode. I grounded the yellow/purple wire in the drivers door. Started right up. Just need to put the panel back on. It had 3 wood screws holding the whole door panel on.
'93 Grand Cherokee
'90 Suburban
'65 Lotus 7
