Pic Request Prop shaft heat shield WJ 4.0 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Pic Request Prop shaft heat shield WJ 4.0
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 08-26-2008, 07:51 PM   #1
moberg12
It seems that the heat shield protecting the front of the prop shaft on my jeep fell off. Can anyone take a pic of this for me, so I can get an idea of how to fix the problem. Second question the lack of a heat shield has melted the boot, is there a 2 piece replacement
Thoughts?
moberg12 is offline   Reply With Quote
Unread 08-26-2008, 08:03 PM   #2
indept
The fsm for my 2000 wj only lists 2 floor pan heatshields, none for the prop shafts??
2000 WJ 4.0L 42RE 242 TC
172,271 miles & counting
indept is offline   Reply With Quote
Unread 08-26-2008, 08:06 PM   #3
moberg12
I know it was there, I can see where the welds broke off the exhaust pipes
Unread 08-28-2008, 12:21 AM   #4
moberg12
bump...........
Unread 08-28-2008, 05:04 AM   #5
ratmonkey
Living dead mod
ratmonkey's Avatar
you mean the heat shield around the downpipe? get some header wrap if you're really concerned.
ratmonkey is offline   Reply With Quote
Unread 09-25-2008, 12:08 PM   #6
moberg12
Originally Posted by ratmonkey View Post
you mean the heat shield around the down pipe? get some header wrap if you're really concerned.
Back from the dead, It is the heat shield on the down pipe, which protects the front Prop shaft boot. Somehow my heat shield broke off, and it has left me with the front CV boot completely melted, I went to jeep, and they said the only fix would be to replace the whole prop shaft, and it is a jeep only part, is this correct? They wanted nearly $500 just for the part, there has got to me another source?
Unread 09-25-2008, 01:34 PM   #7
Jeeples
Here ya go:
http://www.partsamerica.com/ProductL...pe=945&PTSet=A
Just need to know which T-case setup you have, and you're golden.
I would recommend that you replace the entire axle and not just the boot as well. If the boot has torn/cracked/melted and the grease inside has leaked out that means the CV joint inside the boot has been operating without proper lubrication. Most CV axles can go bad due to lack of lubrication in around 5 hours driving time.
His: '96 ZJ, 5.2 Limited, stock, Maxxis Bighorns, '703 Injector Swap
Daily Driver: '05 SRT4, Stock turbo, 252 WHP, 321 FTLBS.
Hers: '03 WJ, 4.7 V8, Kolak Exhaust, IRO 3", JKS TB, KOR TB Bushings, 32" Cooper ATP's.
Jeeples is offline   Reply With Quote
Unread 09-25-2008, 01:57 PM   #8
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
He is looking for the driveshaft, not an axle shaft.
ArloGuthroJeep is offline   Reply With Quote
Unread 09-25-2008, 03:55 PM   #9
moberg12
Correct the front drive shaft. I am not spending $500 just for the part at jeep, guess I will be trying to find one in the junkyard.
anyone got one?
Unread 09-25-2008, 04:36 PM   #10
Bama_WJ
Bama_WJ's Avatar
anyone got one?
x2 on getting one from a junkyard. I got my replacement front driveshaft for $30 off a 99.
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Newest Addition: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel.
facebook. - Wheeling pictures and videos.
The Jeep Wave. Bringing it back.
For Sale Now:
- WJ JKS Shock Conversions
- OEM WK Springs
Bama_WJ is offline   Reply With Quote
Unread 09-25-2008, 05:51 PM   #11
Jeeples
Gotcha, he mentioned front shaft and I assumed axle shaft.
