Permatex “The Right Stuff” - anyone experienced with? - JeepForum.com
post #1 of 3 Old 12-30-2003, 09:32 PM Thread Starter
SBrudzinsky
SBrudzinsky's Avatar
Hi,
Did anyone use Permatex “The Right Stuff” as a differential sealant (gasket maker)? I'd like to ask you a few questions.
1. Bsed on your own experience - how long after applyign on the cover's surface should I wait before place back the cover onto the diff's housing?
2. How long you let covers sit for (in minutes or hours) before you start adding the gear lube?
3. After the whole process done, how long should I wait before I can return to driving?
Thank you very much in advance for your thoughts!
SBrudzinsky is offline
post #2 of 3 Old 12-30-2003, 10:53 PM
AprilzWarrior
AprilzWarrior's Avatar
OK.
1. Apply the goo on the housing approx 1/4" thick (No Gasket) Dont wait just throw the cover up there and start 2 bolts, I go top and bottom then the rest.
2. By the time you get all the bolts in and torqued, you can add lube.
3. Go get some (no wait time).
I only run the Black FYI, its also Sensor safe so go crazy !
AW
AprilzWarrior is offline
post #3 of 3 Old 12-31-2003, 12:17 PM Thread Starter
SBrudzinsky
Originally Posted by AprilzWarrior
OK.
1. Apply the goo on the housing approx 1/4" thick (No Gasket) .....
AprilzWarrior,
Thanks for your response and comments.
The only question is - Are you sure I need to apply the goo on the housing? Why not on cover?
Just curious ...
Thank you so much again!
Happy New Year!!!
ZJ stuff runnerboy2010 ZJ Grand Cherokee Forum 13 10-16-2008 12:11 AM
Control Arm Replacement...Help needed from experienced people! Upside ZJ Grand Cherokee Forum 14 11-14-2007 11:12 AM
Experienced cutters needed! 99redwj ZJ Grand Cherokee Forum 6 12-04-2006 09:30 AM
Have you ever experienced these faults? curt93t/t ZJ Grand Cherokee Forum 4 11-18-2006 08:44 PM
A couple of questions for the experienced... mejifair WJ Grand Cherokee Forum 11 07-17-2003 12:47 PM
