performance radiators???? - JeepForum.com
post #1 of 3 Old 07-31-2003, 08:35 PM Thread Starter
f14x4
so the time has come... i have to change my radiator. i had a small pin hole that was pretty much harmless until last week when my power steering pump blew and i overheated cause my belt flew off. well not directly but you get the point. so im assuming because of the overheat the hole is now niagra falls.
basically i need a new rad. so besides getting oem. are there any hp 's out there that i should check out?
(0IIIII0)
THERES ONLY ONE
f14x4 is offline
post #2 of 3 Old 07-31-2003, 08:59 PM
whitevette
whitevette's Avatar
http://www.jeep4.0performance.4mg.com/cooling.html
Darkness is deaths ignorance, and the Devils time.
'96 Grand Cherokee Laredo
'93 Taurus SHO
'77 Corvette L-48
'74 Land Cruiser FJ40
whitevette is offline
post #3 of 3 Old 08-02-2003, 12:16 AM Thread Starter
f14x4
it seems as if hes taklin about a cherokee...will that work for a grand cherokee? im ordering a t-stat and housing tmo along with a hd clutch for the fan...i gotta get a rad. or should i just replace the stco one with the hd fan clutch and the new 160 degree t-stat?
(0IIIII0)
THERES ONLY ONE
f14x4 is offline
Advice on radiators ZJ_Richie ZJ Grand Cherokee Forum 24 08-09-2013 04:32 PM
radiators 97 ZJ Steve ZJ Grand Cherokee Forum 18 02-05-2008 02:15 PM
after market radiators? rustycherokee18 ZJ Grand Cherokee Forum 1 04-09-2007 10:19 PM
Aftermarket radiators? MSU.WJ ZJ Grand Cherokee Forum 5 08-20-2006 09:31 AM
performance throttle body for 4.7 HO and performance cat converter mikkjroverland WJ Grand Cherokee Forum 0 02-07-2004 02:08 PM
