Peice that holds electric fan blade to the e-motor - JeepForum.com
post #1 of 5 Old 03-22-2013, 06:27 PM Thread Starter
Scottie350
Ok my 9ers cooling fan blade fell off... Its sitting in the shroud thought the motor popped but turned out this was the problem, Wat holds it on there? Even the dealer couldn't tell me, I've tried a few things to jimmy rig it on. But the high rpms just kicks them off
Scottie350 is offline
post #2 of 5 Old 03-22-2013, 07:31 PM
newfieZJ
Don't know if you can get it or not but this is it (off my spare fan)
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 5 Old 03-22-2013, 08:21 PM Thread Starter
Scottie350
Ya that. Any idea what I could use to jimmy rig that?
post #4 of 5 Old 03-22-2013, 08:27 PM
newfieZJ
I'd probably try a 16 gauge flat washer that fit and use tie wire tied tight with pliers in the slotted portion of the shaft . That sir would be a last resort and certainly a jimmy rigged fix
newfieZJ is offline
post #5 of 5 Old 03-22-2013, 08:34 PM Thread Starter
Scottie350
That sir sounds like an idea haha
