PCV Valve on Valve Cover? - Page 2 - JeepForum.com
post #16 of 23 Old 01-20-2010, 08:47 PM
melk
Thanks for the info. Any pointers on how to remove the valve cover?
melk is offline
post #17 of 23 Old 01-21-2010, 04:20 AM
xjokee
It should pop right off. It did on my '02 WJ. My XJ needed a gentle tap with a rawhide mallet. DO NOT pry on the lip of the cover with a screwdriver!
Mike
~ When in doubt........Throttle out! ~
xjokee is offline
post #18 of 23 Old 01-27-2010, 07:57 AM
melk
Do you need to replace the gasket when you take the valve cover off? I know you should, and I will at some point but it's like a $40 gasket.
I'd like to take off the cover and clean up the crank case, but I guess I'll just wait until I can afford to buy the replacement gasket.
melk is offline
post #19 of 23 Old 01-27-2010, 08:38 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
Make sure you also replace the grommets that hold the valve thingys in the valve cover.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #20 of 23 Old 01-27-2010, 10:57 AM
00JGC00
Originally Posted by Kruzin View Post
The problem with this is that technically this is part of the emissions system. And if you are in an area that requires inspections, it would fail the visual inspection for removing factory equipment.
Put on a catch can and then you can still be legal and keep the crap out of your intake. They're cheap to buy and/or easy to make yourself. The WJ has a PCV valve that I put a catch can on AND it has a continuous crank breather to the intake (explian that one!). I plan on putting a catch on that line as well.
"The" Matt | '00 Limited WJ | "The White Wolf" aka "Willow" aka "Cool Whip" aka "Sweet 'N Low" aka "AKA"
Utah JeepCrew #39 | Club Matt #1
December '11 GCOTM | Build: http://www.jeepforum.com/forum/f197/life-times-979511/
00JGC00 is offline
post #21 of 23 Old 03-04-2011, 01:58 PM
greenzj94
1994 ZJ
Thanks for the info guys
Getting ready to replace the CCV on my 94 and just wanted to to thank everyone for the information. Someone mentioned getting a hold of a Jeep service manual other than the Haynes one...where can you get them I didn't see any listing on Amazon.
Thanks all.
Mark
greenzj94 is offline
post #22 of 23 Old 06-19-2011, 03:05 AM
TumorNamedMarla
A subscription to alldatadiy.com gives you access to the service manual. The Haynes manual and JeepForum have provided me with answers to all my XJ build questions though. The schematics drawings are nice though.
TumorNamedMarla is offline
post #23 of 23 Old 08-14-2011, 05:08 PM
lakotaed
1994 ZJ
I replaced my gasket once and thought about replacing the elbows, but they were both clear and just needed a blast of cleaner and some work. Still, I was lost as to how to get these hard plastic pieces out...that's right, they were so dang hard that I assumed they were phenolic plastic or something like that. I would have never thought they were rubber at one point. I tried to pop one off and it chipped just like plastic. Maybe next time I have a leak from the valve cover they will come out. At least now I know what I am in for and can prepare accordingly, thanks a bunch.
lakotaed is offline
Should I get an aluminum valve cover? the88thpianoman ZJ Grand Cherokee Forum 11 02-12-2009 04:44 PM
What else should I do with the valve cover off? the88thpianoman ZJ Grand Cherokee Forum 6 02-12-2009 11:58 AM
PCV Valve, tope of valve cover... random155 ZJ Grand Cherokee Forum 9 01-07-2009 10:15 PM
Valve Cover Leak oct7brian ZJ Grand Cherokee Forum 22 09-10-2005 06:39 PM
Valve Cover Replacement boilingpoint ZJ Grand Cherokee Forum 3 05-06-2004 03:03 PM
