PCV Valve, tope of valve cover... - JeepForum.com
post #1 of 10 Old 12-04-2008, 08:45 AM Thread Starter
random155
Ok, so i replaced my valve cover gasket yesterday. The problem I have is i broke the plastic vacuum plug towards the rear of the valve cover. I only broke the plastic rim not the actual tube that connects to the rubber tubing. I goes back in, and connects no problem. The question I have is, what exactly is this piece called and do you think i need to replace it???
random155 is offline
post #2 of 10 Old 12-04-2008, 08:48 AM
-Joe-
-Joe-'s Avatar
I guess you have a 4.0?
No pcv valve on there..
Theres a CCV elbow and grommet..
You can pick them up a the dealer.. Not expensive.. I am somewhat certain the front elbow is a little different from the rear. But both elbows and grommets can be had for less then $20..
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #3 of 10 Old 12-04-2008, 08:52 AM Thread Starter
random155
Yeah its the 4.0, and sorry meant ccv, like i said the elbow is intact, and the piece fits snug into the grommet but the plastic that sits on top of the grommet is broken...I dont see how this broken piece would prevent any further air but just curious...
post #4 of 10 Old 12-04-2008, 08:54 AM
-Joe-
-Joe-'s Avatar
So the ring at the bottom of the elbow is broken?
If the grommet is really hard I would go ahead and replace them.. In the process you might break it off more and end up removing the cover which sucks.. but thats up to you..
I suppose you could rtv around the ring if you wanted..
- Joe -
-Joe- is offline
post #5 of 10 Old 12-04-2008, 09:01 AM Thread Starter
random155
yeah the flat part that sits on top of the grommet, basically gone halfway around the elbow.. I guess ill just go and replace both of them.
post #6 of 10 Old 12-04-2008, 10:07 AM
99WJ539918
They are different front to back in color (one black and one grey) and the valve itself. It's not the end of the world, but try not to cross them up.
99WJ539918 is offline
post #7 of 10 Old 12-04-2008, 10:07 AM
JrMechanic
My front one is broken and taped off, and my rear one is missing the bottom grommet and the plastic hose is RTV'ed into the plastic. I was looking at some that seemed similar at Advance the other day, does anyone know if they are the same?
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #8 of 10 Old 01-07-2009, 12:57 AM
AvigdorAharon
One more question:
How can I pull out the CCV? I tried to pull it, without success.
Are there some tips how to do it?
Thanks,
Avigdor
AvigdorAharon is offline
post #9 of 10 Old 01-07-2009, 02:05 AM
teenwolf1393
you can get both of them from the dealer for around $10. i gotta get the front one
teenwolf1393 is offline
post #10 of 10 Old 01-07-2009, 10:15 PM
AvigdorAharon
Thanks!
I asked how can I disconnect them from the value cover?
Avigdor
PCV Valve on Valve Cover? Krayzie949 ZJ Grand Cherokee Forum 22 08-14-2011 05:08 PM
Should I get an aluminum valve cover? the88thpianoman ZJ Grand Cherokee Forum 11 02-12-2009 04:44 PM
What else should I do with the valve cover off? the88thpianoman ZJ Grand Cherokee Forum 6 02-12-2009 11:58 AM
Valve Cover Question? Jay1982 ZJ Grand Cherokee Forum 3 03-29-2006 03:32 PM
4.0 I6 Valve Cover/Maintenance. FullForceSound ZJ Grand Cherokee Forum 4 02-02-2006 02:24 PM
