Pcv Valve In 01 Wj V8 - JeepForum.com
post #1 of 5 Old 02-04-2006, 01:24 PM Thread Starter
mrtoner
OK - I'm stumped. Where is the PCV valve on this?
This is so different from the '94 we had; in fact, I can't even see the spark plugs!
mrtoner is offline
post #2 of 5 Old 02-04-2006, 03:21 PM
mbogosia
1987 MJ Comanche
I am a new, but I think I read a thread saying it is mounted on the line connected to where you fill the oil up. You can see it right next to it.
mbogosia is offline
post #3 of 5 Old 02-04-2006, 03:49 PM
AgitatedPancake
I dont know about the PCV valve, but just for your knowledge, each spark plug has its own coil, so you should see 4 per side. It is a small square dark grey box thingy with a tube going down into the engine. That tube connects to the spark plug =D
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #4 of 5 Old 02-04-2006, 03:55 PM
zjay
Look for the hose to the oil filler housing/neck/whateveritis. (on the side of it facing the air filter box) Don't break the plastic, but twist/pull the hose off the housing. You just pulled it off the valve. Then just twist the valve (forgot which way) about 1/4 turn or so and wiggle it out if its stuck a little.
96 GC Limited V8 245,000 miles Scrapped
04 GC Limited 4.0 264,000 miles
96 GC 4.0 175,000
zjay is offline
post #5 of 5 Old 02-04-2006, 04:23 PM Thread Starter
mrtoner
Thanks, all. Got it done.
Gotta love this forum....
mrtoner is offline
PCV Valve on Valve Cover? Krayzie949 ZJ Grand Cherokee Forum 22 08-14-2011 06:08 PM
PCV Valve, tope of valve cover... random155 ZJ Grand Cherokee Forum 9 01-07-2009 11:15 PM
94 4.0 EGR valve petey156 ZJ Grand Cherokee Forum 4 11-17-2008 09:24 PM
Need Help With 95 Gc Egr Valve phjohnso ZJ Grand Cherokee Forum 2 12-16-2003 12:28 PM
Pcv Valve CATMAN2 ZJ Grand Cherokee Forum 4 12-12-2003 12:40 AM
