Quantcast PCM Shot??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > PCM Shot???
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 04-13-2009, 11:02 AM   #1
COLDFEAR
PCM Shot???
i was out at a friends house last night and she drove out fine. she sat infront of the house for about 2 hours and i came out and tryed to start her and nothing...the check engine light doesnt come on when i turn the key so im guessing that means the PCM isnt starting up. any advice? i have had problems with the positive battery cable connecting to the battery idno if that would affect it. cause i do have power just not to the PCM.
95' GrandCherokee 5.2L V8
3" Pro Comp lift, 33"s, FlowMaster Super 40
COLDFEAR is offline   Reply With Quote
Old 04-13-2009, 11:55 AM   #2
ZeeJay1997
I would check battery cables and fuses before calling the PCM bad.
97 ZJ, 4.0, 2WD, 3.73s.
ZeeJay1997 is offline   Reply With Quote
Old 04-13-2009, 05:43 PM   #3
COLDFEAR
fuses are all good. and everything else has power....
Old 04-13-2009, 06:31 PM   #4
ZeeJay1997
Save yourself some grief and be sure you are getting battery power, fused ignition, and ground to the PCM. Just because everything else is powering up doesn't mean the PCM is getting power.
I don't have a diagram, maybe someone can tell you which pins to check. With the power up check not showing on the cluster when ignition is turned on, one of two things: power is missing or PCM is indeed shot.
Old 04-15-2009, 10:39 AM   #5
camboman5
If you go to www.jeepslimited.com they have service manuals for most jeeps so you should be able to locate a wiring diagram and everything you need to know about replacing parts for your heep. Be sure you register a username and password, then go to the Download tab at the top (DL tab will only appear if you are a registered member).
Hope that helps.
camboman5 is offline   Reply With Quote
Old 04-15-2009, 11:54 AM   #6
draphty
Been thru this. Check the power and ground input pins at the PCM connector. Also make sure your bulb is good for the CEL on the dash. If you're gettting power and a good ground, and the bulb is good, figure on the PCM. Also, try this, with the ignition on, push your overdrive on/off switch. If the light above the switch does not light up, get yourself a PCM. Hope this helps, if you need pin callouts, go here for a manual posted on-line for a '93 ZJ.
http://www.scribd.com/doc/4790750/93ZJ-Secc-14-Fuel-System
Section 14 Page 70.
Not sure who posted this, but I found it when I was having the same issue. Also search for post's by me on this Forum and on Jeeps Unlimited Forum for more info from others that helped me out. Good Luck!
Thanks!...Draphty
'95 ZJ Limited, 249, 5.2, 2" BB, 31x10.50-15 on Ravine's
'91 XJ Sport, 231, 4.0, 1.75" BB, 30x9.50-15 on Ravine's - SOLD :-(
draphty is offline   Reply With Quote
Glock Forum
