PCM Harness Connector Repair - JeepForum.com
post #1 of 27 Old 02-08-2011, 01:23 PM Thread Starter
cjseipp
1997 FSJ Cherokee
This is the famed 1997 Jeep Grand Cherokee intermittent hard start and stalling problems.
The car and I live in South Florida so there is no extreme ambient temperature fluctations.
I have good fuel pressure and spark.
There were several issues that have been resolved.
Battery post causing bad ground, fixed.....ran good for a while.
During a cold snap, hard start became an issue......Coolant Sensor and Intake Air Sensor checked good for proper resistance at varying temperature ranges.
Found out that the Idle Air Control Motor was sticking, replaced it and ran fine.
At the beginning of the problems I took the PCM to the Auto Computer exchange shop in Davie Florida and they run a bench test simulating varying engine run conditions. PCM was fine.
Tried the backing out of the PCM mounting screws, (LOL) thought I had it licked,
Finally found issue with the White and Grey connectors on the PCM.....
I have tried the various securing methods, tie straps etc....again it would be fine for a while then back to the same old issue.
Used the Electric Contact Cleaner product on the PCM pins and the Harness Connector mating holes. No Go.
Decided to begin disassembly of the Harness Connector. First stage was to remove the back piece to expose the wires, Would get the engine running and then carefully manipulate each wire, Found 2 that would make the engine purr or could get it to go rough and shut it down.
So the adventuresome one that I am, I decide that I needed to get the connectors themselves.
I have now access to the female connectors that were in the White Connector Block.
I thought they were split connectors and I could give each a gently squeeze with some fine needle nose pliers to close them and create a better contact.
Before I proceed on this fine South Florida afternoon. I was hoping someone else had gone down this path......
Hope some brilliant suggestions will come my way.
Thanks to all that may help
Charlie
cjseipp is offline
post #2 of 27 Old 02-08-2011, 01:57 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
you need a special tool to properly disassemble the connector and reassemble it.
the ends are special as well and should be available through a dealer. though you will likely play hell getting the parts monkey to figure out the parts numbers.
ratmonkey is offline
post #3 of 27 Old 02-08-2011, 01:59 PM Thread Starter
cjseipp
1997 FSJ Cherokee
I have it disassembled and have access to the female connectors on the wires.
A Sawzall and a 3 pound sledge got it apart....just joking......used some jewelers screwdrivers to release the holding clip on the thin blue plate and then slid the pin holder out of the connector body
cjseipp is offline
post #4 of 27 Old 02-08-2011, 05:05 PM
ZeeJay1997
Personally, I prefer a crow bar and hack saw.
http://parts.digikey.com/1/parts/289...60x12009x.html
ZeeJay1997 is offline
post #5 of 27 Old 02-08-2011, 05:59 PM
LordHobbit
May look into replacing those socket pins as well. Digikey should have a part, but it probably won't be easy to find.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #6 of 27 Old 02-08-2011, 07:19 PM
ZeeJay1997
someone on this board has sourced them already. i cant find the post
post #7 of 27 Old 02-08-2011, 09:55 PM
classicmetalman
https://millerspecialtools.spx.com/D...?id=247&gid=15
Another choice?
Robert
93 Laredo 4.0
96 Limited 4.0
Originally Posted by murphydajeep View Post
I say you should still hit something just to let it know you mean business, or shake a hammer at it in a menacing fashion
classicmetalman is offline
post #8 of 27 Old 02-08-2011, 10:10 PM Thread Starter
cjseipp
1997 FSJ Cherokee
DIGIKEY has an extensive array of parts, but true hard to find the specific connector block
cjseipp is offline
post #9 of 27 Old 02-08-2011, 10:35 PM
JS97ZJ
I did the write up on that pin replacement thread, and wish that it cured the shutting down problem but it didn't.
It worked for the entire summer without a hitch and then as soon as the weather got cold....
I've got mine working with the ty-wraps, and have narrowed it down to the PCM. Crushing the outer case in order to make a better connection is futile.
These repair shops that work on these PCMs can't reproduce the faults with these units on their nice comfortable work benches. They should put them in a freezer then test them.
I've got my original PCM torn down to the circuit board and I'm working on the fix but if yours is definitely the connector heres all the info.
http://www.jeepforum.com/forum/f13/c...downs-1089895/
P.S. I still have 20 extra pins and an extra extraction tool if any one is interested.
JS97ZJ is offline
post #10 of 27 Old 02-08-2011, 10:55 PM
dundee23
i had mine runing good for bout 2 weeks , i'm going to buy a new pcm and save the oringinal for experiments. i get so pissed with this thing sometimes bout to say screw it all and drop a carburetor engine and say the hell with all this computer crap. lol why cant it just be simple.
dundee23 is offline
post #11 of 27 Old 02-09-2011, 12:07 AM
JS97ZJ
If you do keep in touch, I have a bunch of info on removing and replacing the potting solution in these units.
Right now I've pretty much have it figured out that the soldering points on the connectors is causing the problem but have one other problem on the main board.
The piece I've pointed to is a crystal frequency oscillator, but the #s on the component can't be cross reference for a replacement part. The potting solution (expansion and contraction due to cold and heat) has literally pulled this piece apart and destroyed the crystal inside so the frequency can't measured so I can locate a replacement. They only cost about $3.
So if you take yours apart please check if the #s are different and in what direction the piece is mounted to the board.
I'm definitely going to fix this SOB!!!!!
P.S. I've got to learn how to resize this.............
JS97ZJ is offline
post #12 of 27 Old 02-09-2011, 06:19 AM Thread Starter
cjseipp
1997 FSJ Cherokee
Thanks ....enjoy your tenacity....very helpful links in your posts.....
Picasa is a free photo editing software by Google.....
Here is the link:
http://picasa.google.com/#utm_campai...mage%20resizer
Or send me the image at cjseipp@gmail.com and I'll resize it for you
cjseipp is offline
post #13 of 27 Old 02-09-2011, 07:18 AM
dundee23
i will keep checking in on this link for some tips and more ideas, it would be awesome to get this issue fixed. are people having the same issue out of the new pcm's too?
dundee23 is offline
post #14 of 27 Old 02-09-2011, 08:06 AM
SGTCornewell
2002 KJ Liberty
mine still works great. its only 3 months old though. if it goes bad, ive got a lifetime warranty........
SGTCornewell is offline
post #15 of 27 Old 02-09-2011, 08:58 AM
JS97ZJ
Here is the link:
I just built a system for my daughter,
Intel i7 960 4core, 3 TB HD, 23" LED monitor, 8 GB mem., Blue ray burner, DVD CD R/W, Sb card reader, radeon 9something 1gig graphics board, heavy duty mid-size case w/pretty lights, a heat sink that looks like I could use it as a radiator for my Jeep. All from Newegg. com. Then her boy friend came over and over clocked it, and I can't even resize a picture!!!!!!
Thanks for the link
There no such thing as new PCM replacements unless you upgrade to one of those expensive programmable type.
Even the replacement type from the stealership is a rebuilt. (whatever that means) that's why I'm looking into repairing myself
Originally Posted by SGTCornewell View Post
mine still works great. its only 3 months old though. if it goes bad, Ive got a lifetime warranty........
I think that the warranty is going to come in very handy, but for your sake I hope not.
JS97ZJ is offline
O2 sensor harness/connector location? lma1973 ZJ Grand Cherokee Forum 6 09-11-2013 08:21 PM
Use 5.9 harness & ECU or 5.2 harness & Mopar ECU for 360 swap aaron7 ZJ Grand Cherokee Forum 1 11-16-2008 05:14 PM
Wiring harness repair steelstr45 ZJ Grand Cherokee Forum 1 08-27-2008 11:31 AM
Wiring harness question ... 98 harness in 93?? mjessop23 ZJ Grand Cherokee Forum 1 05-24-2007 09:17 AM
Connecticut Repair Shops Capable of Axle Repair? dogbait ZJ Grand Cherokee Forum 2 02-12-2007 07:28 PM
