PCM bolts - JeepForum.com
post #1 of 20 Old 02-08-2016, 09:53 AM Thread Starter
94grand52
1994 ZJ
PCM bolts
I'm in need of one of the 3 bolts that holds the PCM to the fire wall on a 94 Grand Cherokee does anyone have an extra they would be willing to mail me ?
94grand52 is offline
post #2 of 20 Old 02-08-2016, 11:22 AM
belalerede
If you go to a true hardware store they should be able to hook you up. I do it all the time. Tractor Supply works great as they are cheaper
belalerede is offline
post #3 of 20 Old 02-08-2016, 11:58 AM
Uniblurb
Uniblurb's Avatar
Yeah, I don't think there's anything special about those PCM case bolts and should be able to match one up at about any big box hwd store. After all they have a non-machine screw type thread and just thread into the nylon inserts in the firewall. Make sure the nylon inserts are in good shape since you don't really want the PCM case grounded to the firewall.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is offline
post #4 of 20 Old 02-08-2016, 02:13 PM Thread Starter
94grand52
1994 ZJ
Has anyone had to replace the nylon inserts? My local dealer says they are discontinued
post #5 of 20 Old 02-08-2016, 04:06 PM
Uniblurb
Uniblurb's Avatar
I would think if you measured the square hole you could find a square nylon insert which would fit at a parts store like below. You'd just have to make sure the middle hole is a little smaller than the PCM bolt screw-type threads.
http://www.oreillyauto.com/site/c/se...2126/C1965.oap
Not my favorite store but showed up in a search.
Uniblurb is offline
post #6 of 20 Old 02-08-2016, 04:32 PM Thread Starter
94grand52
1994 ZJ
I'm going to try some of those nylon license plate retainers and see if they'll fit in there
post #7 of 20 Old 02-08-2016, 09:23 PM
Uniblurb
Uniblurb's Avatar
I had wondered about those but think the square hole may be larger for the license plate screw nylon inserts. You may end up having to alter inserts to fit and bet others would like to know what you used.
Uniblurb is offline
post #8 of 20 Old 02-09-2016, 08:04 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
2 bolts will do. I'd forget about it.
HighLonesome is offline
post #9 of 20 Old 02-09-2016, 09:37 AM
MrRoundel
That's good. Now I don't feel so alone and vulnerable since I lost one of mine.
That said, there is a guy on "the bay" selling a set of 3 for a Wrangler for $4.95. They look the same as for the ZJ. Come to think of it, I think I sent the seller an email asking about their length. Give me a second while I open another browser and check my "bay" messages...
OK, I'm back. Seller first said they were 2 1/2 long. He then got back and said that they might just be 2", but had to check in the morning, which is this morning.
As was mentioned by others, I'm pretty sure that HD or Lowe's, or certainly a better True Value hardware store, would have something that would work, for less. However, the thing I worry about there is if the threads are different, they might make it necessary to keep the screw in the same insert forever, in perpetuity. This makes things so complicated. In other words, it could ruin the original thread/insert bite.
MrRoundel is offline
post #10 of 20 Old 02-09-2016, 09:50 AM
JonS
If you dropped yours under the PCM mounting area, it is solid and you might find it laying there with one of those expandable magnets.
JonS is offline
post #11 of 20 Old 02-09-2016, 10:16 AM
HighLonesome
post #12 of 20 Old 02-09-2016, 06:57 PM Thread Starter
94grand52
1994 ZJ
I'm going to see if the license plate inserts will work and let you guys know, my mopar performance PCM is tracking to be here next week
post #13 of 20 Old 02-09-2016, 10:24 PM
MrRoundel
Unfortunately, I was switching back between my old and new PCM's, and at one point stuck it somewhere next to top of the radiator. I "flashed" on it just as I pulled back into my driveway. I just drove around the block, so it didn't go far. I took a walk around the block to see if I could find it in the road, but never did. Hopefully nobody found it with their tire. I really did think I'd find it, as I've got eyes like a bird. While it may be in the engine compartment somewhere, I haven't been able to locate it. I even pulled the battery tray, thinking it might have gone under it. No such luck. Like so much else in life,
post #14 of 20 Old 02-17-2016, 05:27 PM Thread Starter
94grand52
1994 ZJ
The nylon tag screw inserts worked fine to mount the PCM if anyone wants to know
post #15 of 20 Old 02-17-2016, 07:50 PM
Uniblurb
Uniblurb's Avatar
Real good to know and do you have any link to them or size? Thanks!
Uniblurb is offline
