passenger side door issues - JeepForum.com
post #1 of 4 Old 07-18-2011, 08:38 AM Thread Starter
biggoofy
I took the doors off from some wheeling this weekend since its so nice out. I out them back on and the drivers side works as normal but the passenger side isn't. Onlybthe speaker is working. My keyless also quit. I am going to look at the wires after work today. Anyone have a similar issue?
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #2 of 4 Old 07-19-2011, 02:12 AM
squazz
Where did you unhook the wires or did you just cut them and splice back together reason I ask is because I wanted to remove mine as well on sunday but could not find a way to unhook wires without cutting
squazz is offline
post #3 of 4 Old 07-19-2011, 06:01 PM
D3V0311
squazz.... not sure if urs are the same due to 5 year difference, but i had to remove my door to reweld a hing that busted off. under the black rubber "shoe" that the wires go into on the inside of door jam, i pulled that off and up the wires and thers a yellow "clip" that retains the actually wire plug into the door, pulled that out and i could seperate the wires the correct way.
D3V0311 is offline
post #4 of 4 Old 07-19-2011, 06:14 PM
VolcomPunk
yea on my 95 when i take the doors off, all i had to do was unscrew the security screw in the shoe that connects all the wires from the door to the body and unclipped it. no cutting or splicing required.
Green Jeep #337
WakeUpNow
R.I.P. Ratmonkey...Your now wheelin with the angels
VolcomPunk is offline
5.9 is leaking water on the front passenger side door Candymancan ZJ Grand Cherokee Forum 9 02-04-2011 11:59 AM
WJ Passenger Side Blend Door Actuator thisguyhasadd2 ZJ Grand Cherokee Forum 34 01-21-2009 07:46 AM
07 wk passenger side window issues 07JGCL WK Grand Cherokee & XK Commander Forum 3 01-04-2009 08:55 PM
04 With climate control issues. only blows hot out passenger side lowrnu ZJ Grand Cherokee Forum 3 12-14-2008 10:57 PM
Passenger Side door has NO POWER help :) coolest_Stan ZJ Grand Cherokee Forum 5 07-15-2005 08:01 PM
