Passenger door hinge is broken in half - JeepForum.com
post #1 of 6 Old 07-06-2008, 12:28 PM Thread Starter
Beckler
1989 XJ Cherokee
Just bought my first Jeep yesterday, a virgin 92 Grand Cherokee Laredo with 82k, and am excited to build it to fit my lifestyle. With that being said, I have a door situation that I need to attend to, before it causes some damage. The door does all kinds of funky stuff, swings up in the air, makes a few horrible noises, and somehow still shuts.
The lower hinge on the passneger front door is snapped in two. It is on the door side from the pin, which makes me believe I can remove the door from the hinge, pull out the pin, install new hinge, and screw the door back on.
First, I have not found anywhere online to buy a hinge for a zj. Searched the forums, and found some people talking about going to a body shop and having it welded back together.
Anyone know where I can buy a hinge? Should I ditich the replacement idea and find a place to weld it back together?
Beckler is offline
post #2 of 6 Old 07-06-2008, 12:58 PM
slowpokedotcom
junk yard item
slowpokedotcom is offline
post #3 of 6 Old 07-06-2008, 01:27 PM
Grdaemon
Grdaemon's Avatar
Can't seem to find anything to help.Just a guide I found googling.
http://www.ktioffroad.com/2008/02/18...nge-pin-in-zj/
X-Cherokee 1991 Limited Hunter Green
Now 1999 WJ Limited 4.7
Bright Platinum Metalic Clear
Grdaemon is offline
post #4 of 6 Old 07-06-2008, 01:44 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
I would definitely get this item at a junkyard. The cost of welding it would be more than a used hinge IMO.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #5 of 6 Old 07-06-2008, 03:15 PM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
I'm pretty sure that the GRAND Cherokee (the ZJ) didn't exist as a jeep model in '92. Also, your ID says XJ. You might want to the Cherokee forum before you buy a ZJ hinge for an XJ. But, in any case Welcome
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #6 of 6 Old 07-07-2008, 09:50 AM Thread Starter
Beckler
1989 XJ Cherokee
Platinum... I was doing a bit of wiki work once I got home, and I was under the impression that the zj came out in 93, also... Then I looked at the title for the vehicle and it says 92. Interesting. Thanks for the heads up on my profile error.
Junk yard sounds like the place. To get the pin out of the hinge, do I need to grind the top off so it will slip out, or is there some sort of clip I have not noticed?
Beckler is offline
97 ZJ door hinge problem YJMCBoy ZJ Grand Cherokee Forum 0 01-26-2009 04:37 PM
Door hinge busted, HELP!!! Reswob ZJ Grand Cherokee Forum 4 12-07-2007 05:23 PM
Door Hinge Rollers? hatchmt ZJ Grand Cherokee Forum 10 02-20-2007 01:17 PM
Door Hinge rwild ZJ Grand Cherokee Forum 7 03-01-2006 05:23 PM
Door Hinge? Astorm WJ Grand Cherokee Forum 2 04-18-2004 08:42 PM
