Parts rig, would these parts swap into mine easily? - JeepForum.com
post #1 of 10 Old 06-02-2008, 01:26 PM Thread Starter
bobotech
Guy on craigslist has a 94 Grand Cherokee with the 4.0 and the 242 transfer case.
I want to swap out my rear end (drum brakes) for the 94 and up disc brake rear end, I hate drum brakes. How can I tell if he has the same gear ratio as I do?
I also want to use his transfer case, he has the 2h/4h part time/4h full time/4 low transfer case, and I want to replace my 249 with it (thats the 242 right?), would that be a straight across swap even though his is the 6 cylinder?
bobotech is offline
post #2 of 10 Old 06-02-2008, 02:03 PM
SpeedyCat3
Survivor
SpeedyCat3's Avatar
The TC "should" be a straight swap, as it should be the same spline count and input shaft length. (They are close enough in manufacturing date) If they are not, you can use the input shaft from the 249 in yours.
For the axle you'd either need to look at the axle plate for the ratio, or check the pinion/ring count to be sure. If the donor does have towing package, there is a better chance that it is 3.73 gears like the one you have now.
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
SpeedyCat3 is offline
post #3 of 10 Old 06-02-2008, 02:13 PM Thread Starter
bobotech
now is it possible just to swap out the rear disc brakes for my drums without doing the whole rear axle thing?
bobotech is offline
post #4 of 10 Old 06-02-2008, 02:14 PM
WJChris
WJChris's Avatar
I also think the new rear disc will need a different prop valve under the hood. Might get his to be safe.
WJChris is offline
post #5 of 10 Old 06-02-2008, 02:16 PM Thread Starter
bobotech
Yup, I was planning on that too.
bobotech is offline
post #6 of 10 Old 06-02-2008, 02:57 PM
ajmorell
ajmorell's Avatar
I'm not positive, but I thought I read that you don't need to mess with the proportioning valve at all when you swap disks.
ajmorell is offline
post #7 of 10 Old 06-02-2008, 04:03 PM Thread Starter
bobotech
I'm going from drum to disc. I don't have discs in my GC.
bobotech is offline
post #8 of 10 Old 06-02-2008, 05:03 PM
ajmorell
ajmorell's Avatar
Yeah I realize that. What I meant to say was that I don't believe you need to mess with the proportioning valve when doing the swap.
ajmorell is offline
post #9 of 10 Old 06-02-2008, 05:46 PM
jeepheller98
if you do the swap, drive it and then evaluation the situation to see if you have to mess with the prop valve
98 ZJ 3" lift homemade snorkel. JKS quicker disco 5.2L 150,000, 31x10.5 pro comp muds
jeepheller98 is offline
post #10 of 10 Old 06-02-2008, 06:19 PM
UTChavok
Yep thats the 242.
-Ronnie
UTChavok is offline
What parts are interchangable through the years(body parts) rcjustin ZJ Grand Cherokee Forum 1 12-19-2009 11:05 PM
Bought Parts Vehicle - Want to swap everything over now. gabrod72 ZJ Grand Cherokee Forum 7 04-23-2009 01:18 PM
5.9 parts are mine and Q's footinmouth47 ZJ Grand Cherokee Forum 18 11-18-2007 07:24 PM
ZJ parts to change/check before long trip, parts/tools to take with? John in MA ZJ Grand Cherokee Forum 14 11-13-2006 11:44 AM
parts swap Raven ZJ Grand Cherokee Forum 3 01-04-2005 09:49 AM
